RC60i install questions
hale2thechief
My room was pre-wired for in-wall/on-wall speakers. Unfortunately, the wires are in juntion boxes about 9 feet off the floor. The junction boxes are, of course, nailed to wall studs. Here are the questions:
Are the cam locks on the RC60i at the 12, 3, 6 and 9 o'clock positions or are the on the "corners" (diagonal)?
Has anyone mounted these speakers close to a wall stud (so you can lose the junction box)?
Post edited by hale2thechief on
hale2thechief wrote: »
Yes. If you look at the pics it's where the screws are. I'd just cut the hole as close to the stud as you can w/out having the hole over the stud, and get rid of the boxes. There should still be room to use all 4 cam locks. Hope that makes sense.
