Polk MoMo 6x9...
collar
Hi guys:)
Planning on installing a pair of MMC690 in a custom made MDF board at the rear deck of a Renault Clio 1995 Hatchback. The trunk volume is around 170L or about 6 Cubic Feet. I'll be also treating the trunk et al with Dynamat and making sure I've got an airtight enclosure etc..
I've read here and elsewhere that the MMC690 does have a very nice, tuneful and tight bass though not on par with a dedicated sub etc..I'm not a sub bass freak and am mainly looking for a full range SQ but definitely not an anaemic bass reproduction too. I'm also looking to go for a very simple install and don't want to install speakers at the front or dedicated subs etc.. Looking at the build and the specs of the MMC690 tells me it's gonna be a good choice for what I need.
For amplification, I'm thinking of either a Zapco or a Butler tube amp to drive them.
Would greatly appreciate any opinions, advice and feedback on what I'm about to do.
Thanks a lot in advance !
Collar
Collar
Post edited by collar on
i would def. amp those. i tried patching them into my head unit, and they would work for about half a day, then die. just no sound. i plugged them back into an amp and boom they worked again. they are very power hungry speakers. so if you got the momo6x9's and a clean amp, they would sound great. however (there's always one of these) your sound in the rear is going to overpower everything else in terms of clarity. i would pick up another set for the front...mm6500's are a perfect choice obviously. just get a nice 4 channel amp and you can run both sets yo.At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:( -
also, go with Second Skin. you can get a gallon of their spectrum sludge AND 20ft^2 of their version of Dynamat all shipped for around $120 or so depending on locale. i've found that my car aquired a tomblike silence and i can even hear myself breath at times when im rolling down the road at 40 or so. its just a better product in terms of value/performance. and do your doors too. lots and LOTS of noise gets in from there.At Home:
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
I owned a set of MMC690's for about 2 years and to this day swear they are the best sounding coaxial speaker on the market. Excellent choice.
They will serve you very well and will have decent low end extension considering their size.
As for the amp, Zapco all the way baby!!polkaudio sound quality competitor since 2005
ilikesound wrote: »i've found that my car aquired a tomblike silence and i can even hear myself breath at times when im rolling down the road at 40 or so.
LOL if u can hear yourself breath get on the tredmil:p
u can get a Dynamat bulk pack off of ebay for 117$ shiped anywhere in the us or canada, it got my rear deck, trunk, and doors.2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
ilikesound wrote: »also, go with Second Skin. you can get a gallon of their spectrum sludge AND 20ft^2 of their version of Dynamat all shipped for around $120 or so depending on locale. i've found that my car aquired a tomblike silence and i can even hear myself breath at times when im rolling down the road at 40 or so. its just a better product in terms of value/performance. and do your doors too. lots and LOTS of noise gets in from there.
Thanks ILS! I'll take that into consideration. Might be a bit difficult to install a set of 6.5's upfront, need to check the exact depths etc..We'll see how it goes. Thanks again bud:) -
Thanks Mac! Btw, did you ever get a chance to compare a Zapco with a Butler ? if so, what were your general impressions ? Tks again:) -
i would go zapco. what i've heard amazed me. they're some clean amps. again, i've only had experience (and little to boot) with them so find one and check it out.At Home:
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
eloplayspolo wrote: »LOL if u can hear yourself breath get on the tredmil:p
yea, the bulk pack will cost 117 shipped. but you can get a gallon of second skin, AND a bulk pack for the same exact price...
i should hit the gym...At Home:
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
how does second skin work exactly? as far as installation2013 Toyota Prius
Mosconi 6to8 v8 -
well they sell dynamat-esque stuff that's essentially the SAME THING and they also sell liquid stuff. the liquid stuff can be applied either with a paint brush or spray gun at 80psi. just coat the area you're doing once, let dry (45 mins to be safe,) and re-do until you are sure its at least 3mm thick. a couple layers and your car will be dead as a doornail. finish with the second skin dynamat-like product, and i tell you...there's nothing better than a quite car. honestly i cannot tell the difference between dynamat extreme and second skin pro. same thing.
www.secondskinaudio.comAt Home:
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
New to the site and have a question on these Momos.
I have these 6x9s on my tower and was wondering if they can be run at 2 ohms? I understand each speaker is rated at 4 ohms. -
No.
Ohms are a measure of resistance and you cant change it without changing the voice coil.polkaudio sound quality competitor since 2005
Thanks.
So does that mean that I can't connect two pairs of these speakers to one channel of an amplifier to run them at 2 ohms at the higher output rating of the amp?
Some amps say they put out 100 Watts RMS at 4 ohms and 200 Watts RMS at 2 ohms. I was thinking that if I connect two of these together on one channel (parallel?), would I be able to get the higher wattage rating into these speakers? Or would I damage these speakers? -
Most amps will run at 2 ohms stereo so you could hook up 2 speakers to one channel in parallel, but why would you unless youve got 4 speakers youre wanting to run off a single amp.
An amp that makes 100 watts x2 channels at 4 ohms would make around 175x2 at 2 ohms so your speakers would get more power by wiring one speaker to one amp channel.polkaudio sound quality competitor since 2005
zapco amps are quite clean. which one are you looking at?
I'm amazed they still make 6x9's... I thought those died in the 80's?
