box volume for mm 8''
ilikesound
what should the volume be for a momo 8''? i am using a sealed box and am not sure if it should be bigger or not..if it is, ill just end up using some polyfill or whatnot. thanks in advance!
At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
Post edited by ilikesound on
.33 cubic feet total interior volume.polkaudio sound quality competitor since 2005
If I were to fit a momo 8inch into a .5 cubic foot box, would this lower the resonant frequency of the sub/box package? would the sub still be able to deliver the same spl compared to being fitted on a .33 cu. inch box?
thanks macAt Home:
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
stock system in new car for now:( -
im assuming that a larger box would yeild undesirable results, the mm series is meant to be used in a small as possible box.At Home:
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
ilikesound wrote: »im assuming that a larger box would yeild undesirable results, the mm series is meant to be used in a small as possible box.
Thanks, I went for the .35 cu.ft. box.:) -
Actually a .5 might sound a little better from a strict SQ standpoint. It may have a flatter response curve.
But the .35 would be just fine as well. At most itll have a small response hump around 40 Hz maybe but this is not a bad thing for casual listening. Itll make the bass seem to have more energy.polkaudio sound quality competitor since 2005
