nOOb question about c300.2
_mo_
Hey folks,
I did a bad thing and got a used c300.2 off of Ebay w/out doing all my research. I got a great deal, mind you, just shouldn't have impulse bought.
Anyway, I'm getting some mixed messages from the forums about the ability of this amp to power 2 polk/momo 10 inch subs. Am I right that if I get two of the MM2104DVC's and then bridge the AMP and wire the coils in series and the speakers in parallel, like this, that it should work well?
Thanks for the help
Thanks for the help
Family Room 7.2.4: S35, S60, S10, MM2104 endtables, TL1
Basement 5.1.2: CS400i, RT55i, RT25, PSW450, MC60
Living Room Stereo: SDA 2a
Post edited by _mo_ on
Right.
A pair of DVC subs would be 2 ohms wired in parallel or 8 ohms wired in series.
Wire both subs in series for an 8 ohm load per sub and then both subs wired in parallel to the amp for a 4 ohm mono load. That is well within the operating range of the 300.2polkaudio sound quality competitor since 2005
That's what I figured. Thanks a lot Mac!Family Room 7.2.4: S35, S60, S10, MM2104 endtables, TL1
