RTi10 system
polkarama
polkarama Posts: 2
edited September 2007 in Speakers
I am looking to buy a Polk speaker system combined with one of the newer/higher end AV receivers such as a Yamaha rx-v3800 or the new Denon 380CI - i would like the power and the ehternet and USB capability. Anyway, am looking at the RTi10's, the CSi5, the PSW 505 sub and for the rear - and the reason for this choice for the rear is because of trying to mount these FROM the ceiling (actually a soffet) in my basement, the Atrium 60's - actually an outdoor speaker. i can't have the speaker hang down low, and so the FSi's are out and i was told it would be better to have a full range speaker rather than a satellite for better rear/surround sound. Any thoughts on this speaker set up when combined with 130w A/V reciever? Specifically too on the Atrium's? Also, how do the Polk's compare with Paradigm's, Monitor 5's to be exact? Thanks so much, I am trying to make decisions within the next couple of days!
Post edited by polkarama on
  • Sherardp
    Sherardp Posts: 8,038
    instead of Atriums go for the Rti4 on the back as surrounds. Welcome to the club. Nice choice on the denon.
  • MSALLA
    MSALLA Posts: 1,602
    Or check out some in wall speakers and mount them in the soffit.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • polkarama
    polkarama Posts: 2
    thanks for the replies. I was looking at the Atrium because they can be mounted flat-mounted sideways underneath the soffet (I can't put in walls in the soffet) which gives me more headroom and because they seemed to be a bookshelf type equivalent in terms of full range. I do not like the plastic, but figure the white will blend into the ceiling white anyway. How do you think the Atrium 60's would sound as rears vs. the RTi4's? Could the 4's be mounted sideways? Any thoughts on the RTi12's vs. the RTi10's. I have listened to both, and the 10's seemed brighter and more up front than the 12's, but I don't know enough if that had to do with the receiver or what. I am a relative newb getting my first adult sound and video system (ASAP - I can't wait any longer), spending about $3k-3500 on the audio part. Any advice would be greatly appreciated. Should I consider a separate amp - this whole concept is new to me as I was just looking for a big honkin' AVR
  • MKZ
    MKZ Posts: 1,068
    IMO you may need the separate amp on either RTi10 or RTi12. Denon 3808ci is a great choice. Check AudioGon.com for some deals.
