mm6502-which wire is positive?
Howard-polk
Hello everyone. I removed my mm6502 set from my door and I forgot which wire is positive
The woofer has a positive/negative definition, but the combo midrange/tweeter unit does not. There is a black wire with a green stripe and a solid black wire. What's strange is that the solid black wire goes to the capaciters so I would assume this is the positive. But the black w/green goes to a common connection and ends up at a red mark on the tweeter, which I would also think is positive. Any help would be appreciated.
Howard
Howard
Post edited by Howard-polk on
Welcome to the forum, maybe Josh knows the answer to this one.
Wow. Vintage stuff. I'm gonna have to see if I even have one to look at tomorrow.
Thanks for the help. If you can direct me, I can upload a picture to remind ya
I'm gonna try a basic attachment....
is one of the connections larger than the other???2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
See the little red mark on the lead?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
You can get a small battery, like a AAA, and take two wires and go from the ends of the battery to the leads of the speaker. If the speaker moves out, that means the positive from the battery to the terminal is the positive. If the speaker moves in, then the positive from the battery is connected with the negative terminal.
-CodyMusic is like candy, you have to get rid of the rappers to enjoy it
