ADCOM GFA5500 vs Emotiva RPA-1
fish976
Hi,
I have the LSi15's and LSiC and looking to purchase either the Adcom or Emotiva RPA amp. Looking for recommendations on which one is better for music.
Theatre System 5.1
Receiver Denon AVR 3805 Pre/Pro
Adcom 5503 amp (front L/R & centre)
polkaudio Lsi15 (Ebony)
polkaudio LsiC Centre
polkaudio RM6600 Surround
polkaudio PSW1000 Sub (Ebony)
Denon 2910 DVD Player
Post edited by fish976 on
I don't think you can go wrong with either one,having said that ,I am a big fan of Emotiva.
I like the two power supplies that the RPA1 has.
The specs on both units are close, try the RPA1 they do have a 30 trial period. -
ok thanksTheatre System 5.1
Denon 2910 DVD Player -
Yeah, definitely the Emotiva. Let us know how it sounds.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
i enjoyed my gfa-5300 which is the sibling of the adcom 5xxx series. However, it wasn't musical enough for me - considering i'm not using speakers that are known for their musicality. My Sig upgrade turned out to be far superior than the adcom, and from what i've heard of emotiva's rep, the same conclusion could also be drawn.
That being said, considering you have lsi's, i'm sure either one would be great. -
Rotel and Outlaw are also good value for the money. Don't think you can go wrong regardless based on these choices.
Here's a review of the RPA-1 for your perusal.
http://www.audioholics.com/reviews/amplifiers/emotiva-rpa-1-amplifier?searchterm=rpa -
Actually I purchased a used Adcom 5503 3 channel AMP for $450 dollars, so I intend on using this for my front's LSi15's and the LSiC then just use the Denon 3805 to drive my surrounds (RM6600) for now until I upgrade them.
Do you think this configuration is good for Music (Stereo) 2 channels also?Theatre System 5.1
i am still trying to figure out which amp i want. please let me know if u like the 5503.Home Theater
lsi 15's, lsi c, lsi f/x
onkyo 805
sunfire tga 5200
toshiba - xa2
panasonic bd30
sony kdl40v2500
svs sb12+
