Inexpensive HTIB
My girlfriends son who is 14 just loves my media room, which frankly he is welcome to use anytime he wants. They just built a house to move near me, which as new homeowners in my fancy neighborhood put them on a budget.
They have a room in the house dedicated to HT pre-wired for on wall. Any suggestions on an inexpensive 5.1 system? Best quality for $350 and under. I can probably provide a spare BW LCR60 for center.
My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
Post edited by hockeyboy on
Look at the polk R series from outpost.
A buddy of mine got 2 R-15's to use as his center for $50 (he is only using one) and 4 R-50's for $60 each. Throw in another $75 or so for shipping and you are there. I still prefer my LSi system to his - but it sounds pretty good especially considering the price difference.
The other (obvious) option would be go retro. You should be able to find a pair of SDA 1b's (or 2b's) and a pair of monitor 7's close to your price. If not - swap the 1b's for monitor 10's and add a center channel. (their first big upgrade could be purchasing the RDO tweets) It would sound killer and not be a ton of cash.
Michael
As an example of the deals out there - I just purchased my Monitor 10's (series 2) from a GoodWill store for $28. I still prefer the sound of my LSi's, but these are much closer than I would have thought and I would have no problem living with a system of all Monitor 10's. I am sure you could end up with 5 of them for less than $300.Mains.............Polk LSi15 (Cherry)
Where are you located?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Onkyo makes a descent HT in a box.
http://www.amazon.com/Onkyo-HT-SR600-Theater-Entertainment-System/dp/B000NZ6JE8/ref=sr_1_23/104-4452997-2587969?ie=UTF8&s=electronics&qid=1188161634&sr=1-23engtaz
