Spiked my speakers tonight...wow!
cstpeter
cstpeter Posts: 387
edited August 2007 in Speakers
I've been too lazy to spike my Von Schweikert VR4jr's for almost a year now, but I finally got around to it tonight. I am amazed by the difference it made! Everything sounds clearer, tighter, more resolved. Bass and imaging are the biggest improvements, but it really helped everything. Even my wife is stunned by the difference.
Just thought I'd share. :)
Von Schweikert VR4-jr
Valve Audio Predator
Denon DVD-2900
PS Audio Digital Link III w/Cullen Level IV Mods
Pro-Ject Xpression w/Blue Point No. 2
Graham Slee Special Edition 2
PS Audio UPC-200
Post edited by cstpeter on
  • danger boy
    danger boy Posts: 15,722
    edited August 2007
    ok. so what do the spikes do for speakers? i have a bit of trouble believing it tightens up the bass and adds imaging. how though? what do the spikes do exactly.
    PolkFest 2012, who's going>?
  • Yashu
    Yashu Posts: 772
    edited August 2007
    Anchor the speaker to the ground. Better foundation means less energy is wasted due to resonances. More energy... well you get the idea.
    My apartment is carpeted so my towers have always used spikes to get a firm foundation, but the hardest part was making sure the spikes were perfectly even. Quality spikes, I hope, would be easier to adjust... I spent hours and my speakers would still wobble slightly. My solution was to turn them upside down and use a flat board set atop the spikes while adjusting.
    I am sure 90% of spikes out there are better than the crappy ones that came with my towers.
    Are you spiking through carpet or are you on another type of surface? If you are on hardwood, I suggest taking a quarter and setting one under each spike so you can use the spikes on hardwood without poking a bunch of holes. I don't suggest spiking into rubber or anything like that because it would negate the purpose of the spikes.
  • cstpeter
    cstpeter Posts: 387
    edited August 2007
    Yashu wrote: »
    That's how I understand it. When you consider a speaker's job is to move air, then I want all (or most) of the energy exerted to do just that, and not move the speaker itself and/or resonate into my floors. Spikes help acheive this goal.
    Denon DVD-2900
    PS Audio UPC-200
