Do I need an amp?
byule
byule Posts: 9
Hey guys,
So here's my situation. My setup consists of RT800i's in front, FX500i's in the rear, a CS400i in the center, and a psw303 sub. I'm currently driving them with a Yamaha HTR-6060 which claims an RMS wattage of 105 per channel. Now the problem is that I feel the sound sounds very "muddy" and flat. Playing at a volume level of +0dB is very loud but I feel it sounds less impressive than most lower end systems. So my question is do I need an external amplifier to drive these speakers or do I just not have them setup correctly. The volume level is definitely loud enough but I wasn't sure if the lower wattage on the amplifiers output is too blame for the pour sound quality.
Any input would be appreciated
  • aaharvel
    aaharvel Posts: 4,489
    edited August 2007
    you could use a 5channel amp. Or if space is an issue, just get a better avr. You can start with B&K, an upper-level H/K, adcom, outlaw, etc... Sure there will be recommendations either way. welcome to club polk.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Mike682
    Mike682 Posts: 2,074
    edited August 2007
    byule wrote: »
    Hey guys,
    First, did you calibrate your system?
    Also, if this unit has an impedence switch in the back, set it to 8 ohms
    If these don't improve your sound then just like aaharvel said, either add an amp or pick up an HK or Adcom, etc.
    Receiver: harmankardon AVR235
    Mains: polk R30
    Center: polk CSi3
    Rear Surrounds: polk R20
    Subwoofer: polk PSW404
    DVD: Panasonic DVD-S29
  • hockeyboy
    hockeyboy Posts: 1,428
    edited August 2007
    I agree with aaharvel. You can get a better AVR- my Marantz 5001 downstairs would drive that nicely. That Yamaha is a 7 channel amp at 90 watts and you are using only 5 channels. Not sure if it is possible but maybe you can bi amp the two spare channels to drive the fronts. Fellow Polkies might have better input than me. My solution is usually to spend more money.
    My Main Gear
    Mitsu HC5000 (Proj.)
    Marantz SR8001 (AVR)
    Sunfire TGA7200 (AMP)
    Marantz DV7001 (SACD)
    Samsung BD-P1500 Blu-Ray
    LSi 15's (Front)
    LSiC (Center)
    LSiFx (Surrounds)
    DUAL SVS 20-39 CS Plus
    (Passive Subs)
    Marantz IS201 I-Pod Dock[/SIZE]
    Panamax M5300EX
    Carada Criterion 106" Brightwhite Screen
    Sunfire TGA 5200 & (4) B&W 605's in the party room
  • engtaz
    engtaz Posts: 7,677
    edited August 2007
    3 channel amp would do or 1 mono and 1 - 2 channel amp. 105 watts a channel is enough to run the back and side speakers. The back and side speakers don't get pushed to hard in HT, so amp is not as important as it is with the front 3 speakers. The general opinion is around 200 watts a channel will support most speakers and speaker upgrades. Mike682 already covert the first thing to do.
    Good luck and have fun,
    engtaz
    engtaz
  • byule
    byule Posts: 9
    edited August 2007
    hey thanks for the replies. As far as calibrating goes i used the built in yamaha auto calibration mic
  • Ern Dog
    Ern Dog Posts: 2,237
    edited August 2007
    If you could borrow someone's amp, it would be a quick way to find out if this resolves the problem. Could also be a problem with your source or speakers.
    Has your rig always sounded this way or did you make any recent changes? I know that I was in heaven for the first year I got my Monitor 70's, then I started to grow more and more dissatisfied with their performance until I couldn't stand them- then I upgraded to Rti10's.
