8Ω amp ≠ 4Ω speaker, 4Ω amp + 8Ω speaker=?
Face
I know, at least with lesser amps, a 4ohm speaker with a 8ohm amp is a big no no.
How about the opposite?
If a amp is rated at 40wpc in 4ohm, would it be a problem to hook up a 8ohm in ceiling speaker that is rated to 100 watts?
Post edited by Face on
Not a problem. The reality is, most of the time, the amp is only outputting a few watts. All that means is that the amp will remain stable when connected to an 8 ohm load, unless the amp is driven into clipping, in which case any amp/speaker combo will have trouble (and your ears as well, for it would be too loud for normal listening) For everyday usage, should work fine.
No but the power available may be as much as halved into the 8 ohm load.
If a amp is rated at 40wpc in 4ohm, would it be a problem to hook up a 8ohm in ceiling speaker that is rated to 100 watts?Testing
Testing
Testing -
new amp would be efficient. what brand?Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon -
It's a multi-room McIntosh. I've decided to go another route though.
Thanks for the help."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
