Do screws count ?
SKsolutions
SKsolutions Posts: 1,820
edited August 2007 in Speakers
While researching speakers, I noticed something that I did almost subconsciously. I count the screws on the driver's basket flange.
Since most makers don't offer a cutaway and/or driver diagrams, I make assumptions about the drivers capability by the number of screws that are required to keep the thing in the cabinet.
I know I can usually track down the driver to the manufacturer and then get more detail, but I won't go that far if there are only say. . .3 screws in a 5" mid-driver.
Anyone else?
-Ignorance is strength -
Post edited by SKsolutions on
  • Dave38
    Dave38 Posts: 101
    edited August 2007
    I don't go by the number of screws securing a driver when deciding on a speaker purchase myself.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited August 2007
    I think my Thiels have four screws on both the Tweeter and Mid-range drivers.
    I did notice on parts express that the pricier tweeters did have more screws. But, usually, I just go by the speaker manufacturer name. As Dave mentioned before I decided to be a smart-****, if I found a good deal on some nice speakers but noticed they only had three screws, I wouldn't pass on them.
    SKS, you haven't been examined for OCD, have you :)
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • rskarvan
    rskarvan Posts: 2,374
    edited August 2007
    Its the quality of the screw that counts!!!
  • SKsolutions
    edited August 2007
    rskarvan wrote: »
    AMEN!! If I could get some Variety, that would optimal.
    The thing with the screws is that I didn't consciously know it, but I'm prejudiced against low screw count drivers. I must have been harboring this since I was a kid, and I don't know that it means anything anymore with one-piece and cast baskets, but if a 5.5" driver requires 8 screw to hold that sucker in place, then I would think that the motor structure Must have some serious gonads.
  • brijenjas
    brijenjas Posts: 311
    edited August 2007
    Or the basket is flimsy and needs that many screws to keep it from flexing too much.:D
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited August 2007
    brijenjas wrote: »
    That's probably true. The more rigid the basket, the less screws would be needed to get a good seal.
