Adcom 565 pre question
NeilGabriel
NeilGabriel Posts: 1,487
edited August 2007 in Electronics
This has a headphone input and the sound is quite good, but inserting the headphone plug does not cut out the speaker output. So, if I want headphones, do I have to disconnect speakers each time?
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited August 2007
    No, don't turn the amp on.
  • thejck
    thejck Posts: 849
    edited August 2007
    how high do you have to turn the volume control(how high does it go) on ure preamp to listen to ure headphones.
  • NeilGabriel
    edited August 2007
    RuSsMaN wrote: »
    jeeez....I knew this would be too obvious....umm...but the preamp is plugged into the swtiched outlet on the amp...not really....thanks
    the pre volume level is not very high for decent volume on phones...didnt really check this out yet...
    are you suggesting that turning the pre too high without output to the amp will be a bad thing?
