correct hdmi version? component?
schwerhaiv
schwerhaiv Posts: 72
Hi folks:
I am putting together a home theater and am wondering if it is necessary to upgrade my receiver to HDMI or not. I have a three year old HK receiver with component switching; but no HDMI. I plan to buy an HD70 projector and probably a PS3. Should I upgrade to a newer version with HDMI? If so, do I need HDMI version 1.3, or is any HDMI okay? Please help quickly. Thanks so much.
-Schwerhaiv
Post edited by schwerhaiv on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2007
    Not what you asked but something to consider.
    I grown to HDMI but my AVR doesn't do DVI or HDMI, so my TV has 2 HDMI inputs and I use a Harmony remote to make it all work. My AVR has been down graded to just AR audio receiver, removing video functions all together.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • rskarvan
    rskarvan Posts: 2,374
    edited August 2007
    I too use an "old school (no HDMI)" receiver to provide my audio via optical in jack.
    Personally, I think its risky to let the AVR do the HDMI 1080p video switching.
    The DVD player and the TV need to talk to each other (hand-shake). Sometimes, this handshake is disturbed by going through the AVR.
    Certainly, a direct cable connection is your best bet. No reason to upgrade the receiver. In fact, you are probably better off keeping the audio and video circuits separate.
  • engtaz
    engtaz Posts: 7,669
    edited August 2007
    I don't like HDMI. It does not lock in and slips out of connection easy. I use optical and coxial for audio anyway. I use it only for dvd upconversion purposes only. If you can afford it go for 1.3v.
    engtaz
  • Face
    Face Posts: 14,340
    edited August 2007
    Another thing to consider is the new audio format Tru HD, it can only be passed through HDMI.
    Upconversion is another plus.
  • doggie750
    doggie750 Posts: 1,160
    edited August 2007
    well said bro.
    rskarvan wrote: »
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
  • rskarvan
    edited August 2007
    Face wrote: »
    I use six coax connections between my blue-ray player and my AVR to pass the HD Audio via "External IN". On my blue-ray, this the best way that you can pass the HD AUDIO. Most AVR's don't have a DAC that is capable of decoding the HD AUDIO.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited August 2007
    This is what I do as well with my HD-XA1 via its multi-channel analog output to my HK's multi channel input.
    Works great! My HK has been stripped of almost all functions over the past two years :) I have a 3 channel amp, never use the tuner, hardly use it's DAC. Pretty much has been turned into a fancy paperweight that powers my back two channels and occassionally does some processing :)
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
