Monitor 5b impedance question
k0syak
k0syak Posts: 5
edited August 2007 in Vintage Speakers
Hi!
I've recently become a (proud :)) owner of a pair of Monitor 5b's (SL2000 tweeters version). I've seen their impedance listed in different places either as 8ohm or 4ohm.
Does anyone know what the real impedance is? Measurements would be more than welcome :)
Post edited by k0syak on
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • k0syak
    k0syak Posts: 5
    edited August 2007
    jakelm wrote: »
    Thanks!
    Does this one (taken from the site) relate to the later model?
    Overall Frequency Response 30Hz - 25kHz
    Lower -3dB Limit 43Hz
    Upper -3dB Limit 23kHz
    Nominal Impedance 8 ohms
    Recommended Amplifier Power 20-125 w/channel
    Efficiency 90 dB
  • engtaz
    engtaz Posts: 7,669
    edited August 2007
    polksda.com site has a lot of info on older Polks.
    engtaz
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    k0syak wrote: »
    Thanks!
    Efficiency 90 dB
    You said 5b's right? With sl2000 tweeter? Then thats it.....
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • k0syak
    k0syak Posts: 5
    edited August 2007
    jakelm wrote: »
    I'm totally confused now :)
    What I've quoted is from this page http://www.polkaudio.com/homeaudio/specs/monitor5/
    It seems to be about the newer (SL2500) version,no?
    heiney9 Posts: 25,421
    edited August 2007
    k0syak wrote: »
    Yes, that is correct the Monitor's on the Polk Audio site are Series II and they have the newer sl2500 tweeter.
    As Engtaz suggested go to www.polksda.com as he has scans of original owners manuals and literature for the original series of monitors, etc.
    From memory the early model 5's were 4 ohm nominal and the later model 5's (not Series II) were 6 ohm nominal.
    Why do you ask? Any series monitor 5 is very easy to drive and presents no problem for any receiver.
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited August 2007
    From 1988 manual.
    I've run my 5Bs with several different amps/receivers and never had any problem.
  • k0syak
    k0syak Posts: 5
    edited August 2007
    heiney9 wrote: »
    I was just wondering why all the different specs and which model exactly do I have. It says 5 92597 on the back, is it possible to figure something out of this? And yes, they don't make it hard on the amp :)
  • Ron Temple
    Ron Temple Posts: 3,212
    edited August 2007
    Pull out the tweeter or a the driver...there should be a date stamp on it...might be build date or when it entered inventory, but it will close to when the speaker was originally manufactured.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • k0syak
    k0syak Posts: 5
    edited August 2007
    Ron Temple wrote: »
    Thanks, gotta try it.
    Also, does anyone know if they are magnetically shielded? (i.e. is it safe to place them very close to the computer and the display?)
  • NeilGabriel
    edited August 2007
    They are not magnetically shielded. This is vintage (pronounced, vin-taaahj).
    The cabinets are quite dense, but I had a pair of 10Bs near my rear projection LCD and definitely got some interference on the edges. I was worried about pulling a mid out, but they come out easily, though you need to be careful not to let it slip and snap a connection as they are heavy.
