Explain this sub phenomena....I don't understand
Midnite Mick
Midnite Mick Posts: 1,591
I have moved the equipment around (awaiting the Aragon 2005 arrival this evening) and am recalibrating the individual channel levels with the pre/pro's onboard level adjustment and mic. Anyway, I have also been playing with the gain level on the QSC amplifier and the following occurs:
QSC on max gain - pre/pro sets the sub channel at +9
QSC 12 oclock - pre/pro sets sub channel at -1
QSC 9 oclock - pre/pro set sub channel at -8
I should also note that the higher the gain is set on the amp, the louder the sub plays during the set up process. Having said that shouldn't the pre/pro set the channels higher with less gain...this is weird to me? Can anybody explain this occurrence?
Thanks,
Mike
Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote
Post edited by Midnite Mick on
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2007
    Thanks,
    Mike
    It seems like the pre/pro is doing this in the opposite direction. My Onkyo AVR does this too, but when it says +5db it means the sub is 5db hot, so internally it lowers that channel 5db. To the user it looks like the unit is increasing the sub level when the sub gain is high, and decreasing the sub level when the gain is low, but in reality it does the opposite.
    Weird.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Midnite Mick
    edited August 2007
    appadv wrote: »
    Weird.
    It is like those are measurements and not the adjustments?
    Thanks,
    Mike
    Consonance cd120T
    Usher CP 6311
  • Serendipity
    edited August 2007
    Thanks,
    Mike
    Yes, my Onkyo displays the measurements instead of the adjustments. It was a bit confusing at first because I would turn the sub down and get -12db, and then turn the sub up and get +5db. But then I realized what it was doing, just the opposite of what is reported on screen.
  • cnjvh
    cnjvh Posts: 253
    edited August 2007
    You're looking at the knob upside down when turning it??
    j/k
    No earth robot is going to tell ME which button to press!!
    --Stuff--
    Front: Polk Audio RTi12
    Center: Polk Audio CSi5
    Surrounds: Polk Audio RTi8 (x4)
    Sub: SVS PB10-ISD (Dual)
    AVR: Denon AVR-3805
    Blu-Ray: Panasonic BD30
    Display: Sony KDL-55NX720B
    STB: Xfinity X1DVR
  • Midnite Mick
    edited August 2007
    cnjvh wrote: »
    j/k
    The 4 rubber knobby things on the amp go on top, don't they?
    Consonance cd120T
    Usher CP 6311
  • Serendipity
    edited August 2007
    I think so...
    j/k
