RM10 Connector Help?!?!
Ryan51287
Ryan51287 Posts: 6
I just received my Polk Audio RM10 speaker package today with the RM101 satellites and RM201 center. Upon looking at their rear binding posts, I quickly noticed that the banana plugs that I ordered (still on the way from MonoPrice) aren't going to fit because the angle and depth of the binding posts leave little room around them within the speaker housing. The banana plugs will simply be too long to fit inside the inset hole that the binding posts sit in on the back of the speakers. I can't seem to find a good price for any angled speaker pins that are comparable to the awesome price I paid for the MonoPrice banana plugs. Or, if anyone can comment on how well the Monster FlexPin or a similar product I'd be willing to get them if anyone knows of any sites with prices comparable to what I paid for the banana plugs.
Post edited by Ryan51287 on
  • doggie750
    doggie750 Posts: 1,160
    edited August 2007
    IMO, for RM series stick with the basic, no need to upgrade your supplied wires/ plugs. It is overkill.......n/a. You keep your bananas for later use.
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
