Audio Installation Advice & Help
jamas33
jamas33 Posts: 89
edited August 2007 in Car Audio & Electronics
I'm in the process of buying a 2002 Mercedes CLK-55 AMG
I was told it would be difficult but not impossible to put an aftermarket system in it. Seems like the system is fiber optics and need to be taken out and a whole new wiring installed? Anyone have experience in this or can recommend a shop in the Los Angeles County area. Preferably Long Beach? The system in the car is ok. Navigation/Bose etc.. etc.. but I want to put the polk SR speaker system all the way around and one SR-12 Subwooder. Btw its a convertible so I need to know how that would affect the room in the trunk for the sub system.
Thanks for the help and recommendation
Equipment List:
Head Unit: Kenwood Excelon XXV-005
Planet Audio P13.3
Ipod 60 GB
XBox
AMPS:
Kicker KX1200.1
Kicker KX850.4
Speakers:
Front: Kicker RS65
Rear: Kicker RS65
Rear Deck: Pioneer 4x10 (AAARGH)
Subs: 2 Kicker 15L7
my car: http://www.cardomain.com/ride/571313
Post edited by jamas33 on
  • csnut18
    csnut18 Posts: 48
    edited August 2007
    This car obviously would need a lot of custom fabrication and work to get the system in. Their is no dash kit made so right off the bad you need something custom there. You wanna go to a high end shop that works on these cars. I had bad experiences in the past with crappy shops.
