LSI25/AMP hookup
askinquestions
After trying to get an amp, I finally received and hooked-up my amp to my speaks. I purchased a Sunfire Cinema 5 channel and after hooking it up I was left scratching my head. For the fronts, you have an option of voltage and current source. I currently have them on the Voltage source, but was looking for some advice as to if I should switch to current source. My yamaha amp did a pretty good job driving the 25's as it has 4ohm. The sunfire makes these things scream. Any recommendations on anything to improve sound would be appreciated.
Soon to come lsic and lsifx.
Post edited by askinquestions on
Read the Sunfire manual, it tells you which one will give you the best results for each application.
Basically you can use either one. They suggest using the Current source if you have Electrostatic, Planar Magnetic or Ribbon speaker.
http://www.sunfire.com/pdf/Cinema%20Grand%20and%20Signature%20Series%20II%20Architects%20Choice%205-Channel%20Power%20Amplifier%20Manual.pdf
Congrats on your purchase!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
I would Bi-wire them off the amp.
Go to the link that cfrizz supplied
http://www.sunfire.com/pdf/Cinema%20...r%20Manual.pdf
Go to page 18.
Shannon50" Samsung Plasma
Sony STR-DA4ES "use as Pre/amp"
Pioneer Elite DV-45A DVD Player
DLO HomeDock Deluxe iPod docking station
Directv HR20 Sat. Receiver in black
Sunfire Cinema Grand 7 Signature Amp
Monster Cable AVS2000
Monster Cable HTPS 5100 MKII
Polk LSi 9's Front R/L
Polk LSiC Center
Polk LSiFX R/L Surround
Polk LSi 7's Rear R/L
SVS PB12-Plus/2
Velodyne SMS-1
Sony PS3
Click Here To View my Rig -
I'm using a 7.1 right now, so I don't want to bi-wire. Hell this system I have now blows paint off the walls, can't wait to add other speaks. I was just curious about the 2 set-ups on the amp.
Thanks for replies....
