RTi8 Leg Removal
Does anyone know if the legs that the spikes go into be removed? I need to put them inside of a custom built entertainment center, and while there is enough room inside the cavity, the face frame is too narrow to get the legs in there. I could put them back on I *think* once the speaker is in.
Thanks.
Thanks.
The legs (2) are actually a cradle that screw into the bottom of the cabinet. They won't be on the speaker when you purchase, they are embedded in one of the foam endcaps...so no problem.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE
