Anyone heard of these amps?
BrettT1
BrettT1 Posts: 560
edited August 2007 in Electronics
I noticed these high power ss amps that appear to be common ground. http://www.d-sonic.net/ I thought the Magnum 1000s might power the 1Cs quite nicely. Opinions, please.
Post edited by BrettT1 on
  • Gaara
    Gaara Posts: 2,415
    edited August 2007
    The Magnum 1000s uses 2 1000asp modules in the same chassis. Many different brands use these modules, including Bel Canto, Jeff Rowland, EVS, Red Dragon Audio, PS Audio, Acoustic Reality, Wyred 4 Sound, Murano, Acoustic Reality, Rotel...I am sure the list goes on.
    If you don't know about IcePower I can fill you in. Basically these amps should have gobs of power, are very quiet, have great dynamics, and run cold. I personally have the EVS 500M monos which use the same modules.
    These things shouldn't vary much between brand because they are plug, the 1000asp module comes with a SMPS power supply. All that is required of the manufacturer is to add connectors and a little bit of wiring, and throw it in a chassis. Because of this most brands should sound almost the same, the only exceptions being EVS and Red Dragon because they both mod the modules which most don't do (nullifies the warranty).
    I have no idea how they would power the 1cs, but with my Gallos they are the best sounding, most dynamic, coolest running, quietest amps I have ever had. The bass is where these really excel, they go deep, hard, and fast.
    If you have any specific questions on Icepower feel free to ask, I have been researching these for over a year now.
    Jared
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2007
    Before I bought the short-lived MF A5 integrated, I was looking at the PS Audio integrated. PS Audio indicated to me that they were non-common ground amps. My SRS's obviously aren't compatible, so be sure you have access to a AI-1 interconnect.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • Systems
    Systems Posts: 14,872
    edited August 2007
    The ICEpower modules are at the leading edge of Class D design.Through an industry connection I was able to obtain a 250asp module to power a subwoofer which it does admirably.I have yet to hear a pair used to power a full range speakers but hope to soon.
    Testing
    Testing
    Testing
  • BrettT1
    BrettT1 Posts: 560
    edited August 2007
    Their site indicates a shared ground, I thought this meant it was common. :confused:
    I think I can power my SDAs with this amp with the original pin/blade interconnect.... am I wrong?
    I also think my speakers are 6ohm.
  • olilugo
    olilugo Posts: 405
    edited August 2007
    would these amps only drive 8ohm speakers from the website it does not have any mention on 4ohm?
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • Gaara
    Gaara Posts: 2,415
    edited August 2007
    They drive a 4ohm load just fine, depending on which spec you look at and distortion % these are rated anywhere from 1000wpc-1175wpc into a 4ohm load.
    Many subwoofers use this technology, so they can handle low impedances quite well.
    These use the 1000asp module found here on B&O's site
  • Systems
    edited August 2007
    olilugo wrote: »
    The model numbers #of the stock ICEmodules is based on their power output into 4 ohm's.They are almost perfect current sources in that the available power into 4 ohm's is about twice that for 8ohm loads.
    Testing
    Testing
    Testing
  • BrettT1
    BrettT1 Posts: 560
    edited August 2007
    d-sonic says the amps are common ground.
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2007
    PS Audio told me otherwise...
    Just saying...
    Wes
  • Systems
    edited August 2007
    I only have a block diagram and not a full schematic for my 250asp.The diagram shows that the neg output terminal is not connected to ground therefore not common ground.If I get a chance I will check the actual unit tommorow.
    Testing
    Testing
    Testing
  • Systems
    edited August 2007
    OK I just checked my module and can confirm it is not common ground.I would expect the higher power modules to be likewise.
    Testing
    Testing
    Testing
  • BrettT1
    BrettT1 Posts: 560
    edited August 2007
    It seems alot of companies don't understand common ground. Thanks for checking it out and letting me know.
  • Systems
    edited August 2007
    Your welcome.
    It does get confusing when companies give you conflicting info.
    Testing
    Testing
    Testing
