Fxi3 Placement Question... From A Newbie
64met
Hey guys,
Recently purchased a pair of XI3's to replace some very dated POS rear
speakers! Any way, had a question about placement... My options are these:
1) Mount them in the corners of my viewing room; somewhat at an angle. OR
2) Directly behind my viewing couch more straight or pointing directly @ my gear?
From a decor stanpoint directly behind is more appealing; but I want to maximize the sound these speakers produce so I wonder if the corner mount isn't better.
Any help is greatly appreciated!
Signed:
THE NEWBIE!
Signed:
THE NEWBIE!
Dedicated HT: JVC RS-2 Proj; Carada 104' fixed screen; Yamaha RXZ-7; Outlaw 7 X 200; Toshiba HDXA2; Blu Ray Panasonic 30; Polk Rti10's;
Csi5; Fxi3 and Outlaw LFM1X Sub; RTi Universal RC
Post edited by 64met on
Stay away from the corners. For a 5.1 system, they should be mounted to the sides of your listening position or on the back wall facing the back of your head. Your room and speaker combination will determine which one is best for your situation.
If the sides are not available to you, looks like the back wall. (approx 3' above your seated position)
Welcome to Club Polk.
There are many good online guides, this one is supposed to be the
The Dolby Guide to Home Theater Sound
If nothing else it's some interesting reading"If the global crisis continues, by the end of the year Only two Banks will be operational, the Blood Bank and the Sperm Bank. Then these 2 banks will merge and it will be called 'The Bloody **** Bank'"
