Monster 3250 amp question
mark090852
I'm looking at a couple of "for sale" listings for the Monster 3250 SS three channel amp. Does anyone have any experience with or thoughts about Monster amps? I'd be using it to drive my two fronts and center channel speakers. Here's a link to the amp's web page.
http://www.monstercable.com/power/productPagePower.asp?pin=1903&LastPage=Amplifiers
McIntosh MA352 Integrated Amp, Bluesound Node Icon Reference Network Music Streamer, SVS Ultra Evolution Pinnacle Speakers, WiiM Amp Ultra, JBL Stage 240 B Bookshelf speakers.
Some people on here bought them & like them just fine. So long as your not paying retail for them, have at it.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
These amps are designed by Richard Marsh, who has a good reputation for building amps in the audiophile community. Don't think of them in the same rep as 'overpriced wire'. They are really great ss amps with a lot of power. I own both the two and three channel models powering my LSi setup. They will beat any ss amp bang for the buck at the sub $1000 street price you can often find them at. Clear highs, increased bass, tightened everything up with better low end slam compared to my denon 3803. And they're often factory sealed new on ebay. Although the quantities available have really dropped off from last year. The meters really show how much (little) power it takes to get even LSis up to hefty volume levels. But you can turn them off if you don't like the distraction.
These amps are designed by Richard Marsh, who has a good reputation for building amps in the audiophile community. Don't think of them in the same rep as 'overpriced wire'. They are really great ss amps with a lot of power. I own both the two and three channel models powering my LSi setup. They will beat any ss amp bang for the buck at the sub $1000 street price you can often find them at. Clear highs, increased bass, tightened everything up with better low end slam compared to my denon 3803. And they're often factory sealed on ebay. Although the quantities available have really dropped off from last year.
Thanks for the info. There's one listed on eBay now that is new, sealed in the box. I'm going to keep my eye on it.
Chedder, would it be possible for you to measure the dimensions of your 3 channel amp? There is a discrepancy on their web page that I have linked on the first post above. At the top of the page it has one set of dimensions listed and further down in the specifications section there is another set of dimensions listed. If it is the size of the top dimensions it is way too large to fit my space.McIntosh MA352 Integrated Amp, Bluesound Node Icon Reference Network Music Streamer, SVS Ultra Evolution Pinnacle Speakers, WiiM Amp Ultra, JBL Stage 240 B Bookshelf speakers. -
Been using two 3250's for almost a couple years with no complaints!
They power four LSi15's, and an LSiC effortlessy. Hardly moving the power meters at ear deafening listening levels.
No plans for upgrading these amps, they are more than I'll ever use. -
17W X 7 1/2H(with feet) x 19 1/2 D
Thanks for the correction Cheddar!:)
The measurements are without the rack mounts. And the depth or length is 20 1/4" with the side wings. Sorry about that! -
17W X 9 1/2D(with feet) x 19 1/2 L
Thanks, Mike, I think it will fit my space just fine. I'm going to have to watch that listing on eBay closely.McIntosh MA352 Integrated Amp, Bluesound Node Icon Reference Network Music Streamer, SVS Ultra Evolution Pinnacle Speakers, WiiM Amp Ultra, JBL Stage 240 B Bookshelf speakers. -
I only see a 2250 or 5150 on Ebay?
Nevermind, I found it.:o -
20 1/4" L including the side wings that help protect the binding posts and other stuff on the back when you move the beast...;)
The two dimensions include or exclude the optional rack mounting kit. Go with the smaller numbers since the amp comes with the rack ears in a box, not installed.
Edit: Oh, they have another set of numbers at the top. Not sure how they got those, but the bottom numbers are more accurate. -
As long as the height is not the 11 7/8" they have listed at the top I might be ok. I think just under 10" is all I have room for, and that wouldn't leave much room for air circulation. They have the height listed in the specifications section as 7.75" with feet. Mike, your measurement was 9 1/2". I wonder if heat would be a problem? Does it run very hot?McIntosh MA352 Integrated Amp, Bluesound Node Icon Reference Network Music Streamer, SVS Ultra Evolution Pinnacle Speakers, WiiM Amp Ultra, JBL Stage 240 B Bookshelf speakers.
Mark,
I measured 7 1/2 " from top to bottom with the feet.
Does it run hot? I'd say it gets pretty warm, but nothing hot to touch. I actually run a couple cooling fans on the very top of mine as they are stacked in my cabinet.
I wouldn't run it enclosed, and I'd defenitly leave a few inches of breathing room. -
They do generate heat. You'll want good air circulation around these amps. But you should have room. My 2250 sits just 7.5" tall off the shelf. The 3250 should be similar. But it's in a rack, not on a shelf so I didn't measure the feet. 6 15/16" without the feet, though. How did you get over 9" Mike?
My bad!! It is a 7 1/2" height!:o
Sorry about that, not feeling to well at the moment.:( -
These are the correct dimensions on the site:
Dimensions Width Without Rack Ears: 17in / 434mm
With Rack Ears: 19in / 484mm
Height With Feet: 7.75in / 193.5mm
Without Feet: 7in / 177mms
Total Depth: 20.25in / 514mm -
Thanks, guys, for straightening all that out. I think I'll be ok with the size. Just have to keep my eye on the Ebay listing and one on Audiogon.McIntosh MA352 Integrated Amp, Bluesound Node Icon Reference Network Music Streamer, SVS Ultra Evolution Pinnacle Speakers, WiiM Amp Ultra, JBL Stage 240 B Bookshelf speakers.
