360 HD-DVD - Component or VGA Hook Up?
VXR8
VXR8 Posts: 291
edited September 2007 in Video Games
G'day all,
Just wondering, for the 360 HD-DVD, which is the better connection type, for playback of HD-DVDs? I have both, going to a Fujitsu 1080i compatible plasma screen. I also have tried both and notice minor differences:
1. With VGA, as we have to suffer black lines top and bottom with the new HD formats, they don't appear as black, as they do with component.
2. PQ appears a bit better with VGA.
Just want your thoughts and the consensus on what the majority believe is the ideal connection.
Thanks in advance.
Regards - Gaz from the land of Oz
Main System
Denon - AVC-4700H
Emotiva - XPA-9
Cambridge Audio - Azur 851C - CXUHD
Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
SVS - PB1000 x 2
Foxtel - iQ4
Belkin - Pure AV PF40
Sony K77A9G
Front Room System
PS Audio - Sprout 100
Cambridge Audio - CXC S2 - CA752BD
Sony - UBX800 4K BluRay
Polk Audio - Legend L200
Post edited by VXR8 on
  • mutelight
    mutelight Posts: 1,054
    edited August 2007
    If you are having problems with the black levels using the VGA connection there is an option in the system settings where you can change the "reference level" which will help with the blacks since VGA typically uses a different color space.
    // Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
    // Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
    // Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
    Photo Gallery
    Movie and Game Collection
  • VXR8
    VXR8 Posts: 291
    edited August 2007
    mutelight wrote: »
    Thanks mutelight - which setting would you recommend? I have it currently set at "Expanded". Would "Standard" or "Intermediate" be better?
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • mutelight
    edited August 2007
    Well expanded should give you the deepest blacks out of the options. Are you still not achieving desired black levels?
    I use component on my display since VGA isn't really an option as my display only supports 1024x768 max (don't ask me why) but I am very happy with the image quality.
    Photo Gallery
  • VXR8
    VXR8 Posts: 291
    edited August 2007
    The actual black levels are fine in the actual movies, but component doesn't appear to light up the black bars top and bottom, whereas VGA appears to illuminate those bars, like an LCD display's back light - like you mentioned above, maybe it has to do with VGAs different colour space?
    My screen resolution will go to 1366 x 768, for which I have set the 360 to that resolution for VGA (1360 x 768 actually), or 1080i for component.
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    SVS - PB1000 x 2
    Foxtel - iQ4
    Sony K77A9G
    Front Room System
  • mutelight
    edited August 2007
    Ah OK, well then you might just want to go with component then since the trade off seems to be only slightly better image quality for better blacks with VGA. I know I would rather have deeper blacks. There is no definitive answer on which is better, it is more of a personal preference.
    Photo Gallery
  • engtaz
    engtaz Posts: 7,670
    edited August 2007
    VGA is my choice. Black are better for me with VGA.
    engtaz
  • krabby5
    krabby5 Posts: 923
    edited August 2007
    I think that is another question where the answer is "it depends on your display"
    My Bravia LCD has a VGA input, but for some reason it doesn't work with the 360. So the decision was easy for me:D
    Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
  • RaysR6
    RaysR6 Posts: 28
    I would think that component is more widespread than VGA though.
