Printing digital pictures
strider
I've got a bunch (~150 ) of pictures from my honeymoon that I'd like to get printed, and I was wondering what method everyone uses to print theirs? Typically I use my Canon Pixma printer when I'm doing a couple at a time, but for this many I'm not certain if I'd get better results sending them out to be done. I've used services like Snapfish before, they were ok, but I found that the print I received was different in terms of color and dimension then the image I saw on my screen.
Thanks,
Ben
Thanks,
Ben
Wristwatch--->Crisco
I take the ones that I want to print on a CD to Wolf Camera and ask them to run it through their processing machine. They "develop" each picture individually and it is the best printing possible. You can also do it online through their website and then go and pick up the pictures later. You can also edit the pictures to know exactly what you are printing instead of them just running it through and it cutting off random parts of your pictures. We have always had good luck with it.I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff. -
I always use Walgreens for large sets of photos. Like you, I just use my Canon printer for small runs, but there's nothing like uploading 100+ to Walgreens and picking them up an hour later.
I'm not sure how their prices are compared to other similar picture printing services, but I never feel like they're overpriced./COLOR] [U][URL="http://www.polkaudio.com/forums/showcase/view.php?userid=68366"][COLOR="Blue"]My Rigs[/U][/COLOR][/URL] [COLOR="Red" Balanced Audio Technology | Revel | Dodd | Monarchy | PS Audio | MIT | Polk | Etc. -
WinkFlash. Like SnapFish, but I liked them better. Plus they're one of the cheaper options, and super fast.If you will it, dude, it is no dream.
+1 to Walgreens. You can send them anywhere in the country there is a Walgreens and pick them up in an hour.
Use some photo editing software (walgreens has this on their site) to crop your photos so that they match the size you're having printed. This way you decide what gets cropped, not the developer. Good luck.
bamadudeAVR: Pioneer VSX-84TXSi (RIP - lightening) / Amp: Sunfire Cinema Grand / Klipsh R-10B Sounbar, LC65fx / Sub: Elemental Designs LT/1300 / TV: Panasonic TH-50PH9UK /SIZE] -
bamadude
That's one of the issues I had. When I crop a picture I crop it so it's proportions are what I want, rather then fitting a standard print size. I have heard good things about Walgreen's developing.
Thanks for the ideas, folks. Keep 'em coming.Wristwatch--->Crisco
