Polk XRT12 tuner and Denon AVR2106
Dear Madam Sir,
Tried contacting both Polk and Denon live phone support and after repeated attempts of 20-30 minutes on hold gave up. I am trying to connect the Polk xrt12 tuner digitally direct to the Denon AVR2106 Receiver, the later having only a mini USB XM antenna connection input.
Can you suggest a source that can assist in figuring out how to connect those 2 instruments?
Thanks in advance,
Paul L, Dallas TX,
callcentertiger@excite.com
Post edited by callcentertiger on
    edited August 2007
    The Polk XM tuner is a receiver, where your Denon AVR2106 is also a receiver. Use one or the other, but I would say the Polk XM tuner over the Denon. As far as hooking up use the optical or the RCA outputs for the tuner, if I understood you correctly.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
Welcome!
Welcome!
