Need help planning out what to get next
1lakerfan
I recently got the Pioneer DEH-P6900UB reciever for my car. I am going to buy the MTX TCE5512X2D enclosure subwoofer and hook it up to the MTX 600XD one channel amp. Now I need to know what speakers will go good with this sub and need an another amp for the speakers. I have a 1995 Nissan Altima.
Post edited by 1lakerfan on
budget?2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
Looking at crutchfield website and the circuity do list as pairs or singles? I dont want dont for one speaker I dont want to spend no more than $150. Where can i look up the size of speakers for my car?
in order to spend less than 150 bucks and get 4 speakers and an amp, u need to steal them.2013 Toyota Prius
Mosconi 6to8 v8 -
elosplayspolo is correct you would have little choice/option if 150.00 is your budget, you would need to forget about what would sound good with that sub, but rather what is available in that price range. only other option is looking on Ebay for someone dumping there system for 100.00 cause the other 50. would be shipping. ( not a bad thing just you need to go to crutctfield online see what fits your car and then start looking 4 that size on ebay).
My fault I ment I dont want to spend know more than $150 for each speaker. and as for the amp know more than $400
suggestens
circuit city has the polk dbs buy one get one half off this weekSR 4 Life
If it was me and that was my budget, i would get 2 sets of DB components for front and back at circuit city with the deal thats going on now, and then get....
http://www.cardomain.com/item/MTX704X
Remember with 2 amps u are going to need distribution block and possibly a better battery.2013 Toyota Prius
Mosconi 6to8 v8 -
I cant find nothing good that fits my car
whats wrong with mine?2013 Toyota Prius
Mosconi 6to8 v8 -
eloplayspolo wrote: »whats wrong with mine?
When you say db you mean the polk speakers right? well most of them dont fit in my car (says the websites) -
nothing wrong with a little modification, and also, u may only need to buy spacers.2013 Toyota Prius
Mosconi 6to8 v8 -
will circuit city do this? (modifiactations)
yes, i used to work at circuit city, they will do anything u ask, but of course it will cost u money. i will say though, they do very clean installs.2013 Toyota Prius
Mosconi 6to8 v8 -
thanks for letting me know but what type of money are we talking. I know it depends on the speakers but just want to know the price range.
How about these polk speakers http://www.circuitcity.com/ssm/Specifications-of-Polk-6-5-2-Way-Component-System-with-External-Crossover-db6501/sem/rpsm/oid/172446/rpem/ccd/productDetailSpecification.do#tabs
with this mtx amp http://www.mtx.com/caraudio/products/amplifiers/xthunder704X.cfm
Two question. These speakers are used for both the door speakers and the rear deck speakers, correct? and will this go good with the subwoofer I said I was going to get in my other post -
Yes,no
Your best bet is to go to Circuit City, tell them youre looking at the Polk DB speakers and the MTX amp listed above. They can tell you better whatll fit your car and how much, if any, modifications will be needed.polkaudio sound quality competitor since 2005
