Need to Bi-Amp?
edited August 2007 in Speakers
I have read a little about Bi-amping, My Yamaha HTR-6090 is rated at 120 wpc and is a high current amp. It also states that it can bi-amp the front left and right speakers by connecting to the surround back terminals as well. so my question is....will this work the same as if i were to purchase a seperate second amp to power them and what will the total power being fed to them be, 240 watts? honestly, I don't want to feel dumb asking that.
second is that the HTR-6090 sufficient to power teh Rti10's (bi-amped) Csi5(bi-wired) Rti4's (rear) and PSW505 Sub.
If I need to get a second AMP (which I hope I dont haveing just bought the Yamaha), then would going to the Rti12's be better seeing as they appear to need the extra power...
I have already purchased the Csi5, ther RTi4's and the Psw505....But im not hooking anything up till I have the fronts.....and I plan on getting all my cables from signal cable...was close to going with Cobal , bu thtey don't offer bi-amping or bi-wiring....although i could get two sets for bi-amping and they suggest there inetrconnects for bi-wiring...but i digress.
Any help is good help.
Post edited by Vicedaddy on
    edited August 2007
    Im not usually this illeterate...at work and have to type fast
    edited August 2007
    unless you are unhappy with the sound you are getting.. don't worry to much at all about bi-amping at this point. sounds like you are not looking to add a second amp.. so i say if it ain't broke, why fix it?
    PolkFest 2012, who's going>?
Welcome!
Welcome!
