Cleaning DVDs. How?
bikezappa
bikezappa Posts: 2,463
edited August 2007 in Electronics
I rent DVDs from netflix and seem to have 30% of the disks skip or freeze at some point during the movie. I then take the disk out and clean it with window cleaner and a new paper towel. Put it back and it works fine 90% of the time.
Does every one have this problem with DVDs?
I never had any problems with a new DVD freezing. Just the netflix rentals.
What would you recommend as a better cleaner?
Thanks for any suggestions.
  • MikeC78
    MikeC78 Posts: 2,315
    edited August 2007
    I use some type of lens cleaner with a microfiber cloth.
  • bikezappa
    edited August 2007
    MikeC78 wrote: »
    Does it help stop freezing of the DVD?
  • MikeC78
    edited August 2007
    I've never had any issues with a regular SD DVD. When I run into any issues with my HD DVD collection, it seems to help the problem.
  • ilikesound
    ilikesound Posts: 355
    edited August 2007
    you also have to wipe it from the inside out, so as not to scratch the surface. in other words, wipe against the grain of the rings, not with them. it will stop seizing of the disc, provided that dirt is the issue.
    At Home:
    Panasonic 42'' TC-L42U12 LCD
    Pioneer VSX-80TXV
    Toshiba HD-XA2
    Sony PS3 - psn "metalguitars"
    Xbox 360 - gamertag "giggidygiggidy"
    Panamax 4300EX
    Polk RTi8's
    Polk CSi3's
    Polk FXi3's. (x2)
    Martin Logan Dynamo (x2)
    Audioquest interconnects and wires.
    Away From Home:
    JVC HDR-50
    stock system in new car for now:(
  • Monster Jam
    Monster Jam Posts: 919
    edited August 2007
    My HK DVD 25 is extremely finicky. I open up my movie when I rent it at Blockbuster for visual inspection, asking for a trade-out if it looks really bad. Just looking at the movie doesn't always cut it, though, because some imperfections (disc irregularity, burn error, etc.) go unseen to the eye as well.
    I clean with rubbing alcohol and cotton ball and dry with soft cloth.
    Do you hear that buzzing noise? :confused:
    billbillw Posts: 8,344
    edited August 2007
    I have a Skip Dr. It cleans up most of your surface scratches in two or three passes (less than 1 minute). Deep scratches are difficult, if not impossible to get out with it. That said, most if not all of my Netflix movies have played perfect after a quick cleaning with the Dr. (I should mention that I only have to use it on the really bad ones, maybe 5% of the ones I get).
    An old fashion way is to use car polish on the disc. Use small circular motions with heavy pressure and it takes out most of the light scratches.
  • madmax
    madmax Posts: 12,434
    edited August 2007
    I wash in warm soapy dishwater and rinse with warm water. Seems to work quite well as I don't have to scrub them or anything.
    BTW, mine have to be really nasty to not play. A layer of chicken grease or similar. :)
    Vinyl, the final frontier...
  • m00npie
    m00npie Posts: 697
    edited August 2007
    madmax wrote: »
    Bingo! I have found that this method works best as well.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited August 2007
    My Netflix HD DVDs have this problem from time to time and I just use the old soap and water trick too.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • bikezappa
    edited August 2007
    madmax wrote: »
    I used to do this with great success also. It's just a little inconvient in the HT room. But I could just wash them all after I open the netflix.
    I guess the window cleaner isn't very good for DVDs.
