banana plugs
simphiwes
simphiwes Posts: 116
edited August 2007 in Electronics
do banana plugs reduce speaker impedance? (a salesman told me this)basically what are the disavatages to using banana plugs if any.
(((((STEREO)))))
System 1(complete)
Front: Rti8
Intergrated: Valve Audio Epsilon
CD Player: Xindak Muse Delux 1.0
Media Player: Mede8er MED 200
Behringer DAC
    VR3 Posts: 29,759
    edited August 2007
    hahahahhahahahhahahahahahahahhahahahahahaha
    Its just a quick connection
    Reduces impedance... HAHAHAHAHAHAHHAHAHAHA
    Go back and kick him in the nuts.
  • simphiwes
    edited August 2007
    why me, i always get these stupid, think they know everything salemen than never give me information worth using, why me?
    (((((STEREO)))))
    System 1(complete)
    Front: Rti8
    Behringer DAC
    VR3 Posts: 29,759
    edited August 2007
    The only downside to them -- some say
    Is reduced contact with the post... since there is less metal or w/e...
    But I like them because they are quick and to me a pretty solid connection
    But my speakers are still 4 ohms, pretty sure about that.
    F1nut Posts: 52,406
    edited August 2007
    There's no downside as long as they are high quality, which would apply to spades also.
    VR3 Posts: 29,759
    edited August 2007
    Never quite saw the point to spades...
    Would be slippery to me - easier to pull out, not really a better connection..
    I would rather use bare wire than spades...
  • simphiwes
    edited August 2007
    i bought audioquest banana plugs, dont know which model tough they were the best the shop had, they seemed like a pretty good connection when i installed them.
    thanks for the response guys.
    (((((STEREO)))))
    System 1(complete)
    Front: Rti8
    Behringer DAC
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2007
    You can get a much much tighter connection with good spades than you can with bare wire especially if you are using stranded wire 12 ga or less. With the wire, the nut squishes the strands and the tightened nut pushes the wires our of the connection.
    I just recently purchased some spades from Vampire to make some jumpers cause my banana holes in the posts are taken. I get a really tight connection with them.
