Larro59
Larro59
May be dumb Question, but salesman could not answer my question.
I just purchased the monitor 50's and they have (2) sets of speaker
connectors on the back. Which one should I use or does it matter!
Post edited by Larro59 on
Hook it up on the low frequencies side....That is the general method from what I have read elsewhere....make sure the jumpers are installed, otherwise no matter what you have hooked up you will receive no sound from the other.....
Way to make the "title" your username!!!
KG -
Look at the manual,
http://www.polkaudio.com/downloads/manuals/home/Monitor_Manual.pdf
under basic hookup diagram, notice that the connection is only to the top terminals and you must keep the brass looking connectors that connet the top and lower terminals.
if you use bi-wire then all 4 terminals will be use, and the brass connectors needs to be taken out.Current HT setup
Mains: B&W 804s
Center: Polk CSi5
Surround: Polk FXi3
Sub: Velodyne DLS-3750R
Receiver: Pioneer SC-07
Amplifier: Sunfire TGA5200
TV: Sony KDS60A2020
DBP: Sony DBP-S350
CDP: Pioneer DV-48AV
Interconnect cables: SignalCable analog II
speaker cables: SignalCable Ultra Speaker Cables Bi-wire
