How to properly clean a projector screen
engtaz
How to properly clean a projector screen. I need some help on ideas.
engtaz
I used a soft cotton t-shirt to clean the inside of my rear projection.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
What kind of screen fabric material is your GrayWolf? Is it a glass beaded screen? These have different cleaning procedures then matte white screens. Otherwise you may damage the screen.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
contact the manufacturer
If that's the case then you can use screen wipes. Just wipe the screen down gently with the cloths and make sure not to press too hard on the fabric.polkaudio RT35 Bookshelves
106 inch greywolf huh, go big or go home, my screen is 126 inch. Just kidding you bro. I read a few threads to use a spray bottle of water, and wipe completely dry and in one direction. Let me know what works for you so I have some sort of idea when my time comes around.Shoot the jumper.....................BALLIN.............!!!!!
