What's the best SVS for music?
Serendipity
Serendipity Posts: 6,975
Hi,
I'm interested in an SVS sub that is well suited for music applications. Although I find their subs to be very good, they aren't as musical as my DIY subwoofer.
So whats the best SVS for music applications?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • MikeC78
    MikeC78 Posts: 2,315
    edited August 2007
    Email SVS, they'll give you the best possible answer.
  • engtaz
    engtaz Posts: 7,671
    edited August 2007
    VMPS I have heard are better for music and SVS better for HT.
    VMPS in FM
    http://www.polkaudio.com/forums/showthread.php?t=55837
    engtaz
  • Serendipity
    edited August 2007
    MikeC78 wrote: »
    Thanks. I did some research on the SVS website and it looks like the 25-31 series is my cup of tea.
    It says "If popular music is your main source of pleasure (which is nearly all above 25Hz)a 25-31PCi or PC-Plus is probably your best choice."
  • Ron Temple
    Ron Temple Posts: 3,212
    edited August 2007
    Probably the little SB12+ will do the sealed trick. Honestly, I don't find SVS subs lacking in musical ability at all...because they trawl so deep they can be subject to wicked room gain and any deep chasms, suckouts, will accentuate the low bass and make one think they don't do a very good job in the upper bass. If you can get them flat, they are extremely musical...takes time and patience...or a second sub ;^).
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • MikeC78
    edited August 2007
    Ron Temple wrote: »
    +1
    Don't forget that the new Ultra has a sealed option. Can't wait until the reviews start rolling for the PB13!
  • Strong Bad
    Strong Bad Posts: 4,278
    edited August 2007
    This whole thing that VMPS is better for music is total nonsense.
    Talk to Ed at SVS and he'll give you the skinny on all things subwoofer. He's great to talk to and is extremely knowledgeable. He'll squash that "SVS is not musical" BS by telling you how it is, not just because he works for SVS.
    Remember, any sub must be setup properly, tested and tuned, then minor tweaking applied to get the most out of it. You can't just find any old spot, plop it down, plug it in and expect magic to happen.
    John
    No excuses!
  • engtaz
    engtaz Posts: 7,671
    edited August 2007
    I did not say SVS was bad with music. It is good for musi.
    engtaz
  • Grimster74
    Grimster74 Posts: 2,577
    edited August 2007
    My guess is the SB12+ is best suited for music out of the SVS lineup due to it being a sealed enclosure although I've never had one complaint about my dual PB12-Plus/2's. The best thing to do is contact SVS.
  • PolkThug
    PolkThug Posts: 7,532
    edited August 2007
    How about a PB10 sealed?
    VR3 Posts: 29,566
    edited August 2007
    the SB12 looks like a fantastic subwoofer. I wonder how it would do in larger rooms?
  • Serendipity
    edited August 2007
    Not sure if it would work well in my 21.5*22*8 room.
  • dkg999
    dkg999 Posts: 5,647
    edited August 2007
    I have the SB12+ running as a low-end extension for my Magnepan 1.6's. It is in a cram packed living room in my apt, so I haven't done anything except plug it in and do some gain and phase adjustment. This sub is very quick, has good range and SQ, and keeps up very well with the bass panels in the Magnepan's. It was amazing how well it blended in without much work at all. I don't run it very loud, but I get the feeling it would work well in a medium sized room. I compared it directly to a Martin Logan Grotto, and a REL Storm III. It killed the Grotto. The REL was better, but probably moved you from an 8 to a 10, the REL was not twice as good for twice the price of the SVS. The Cherry/Rosenut finish on the SVS is really nice.
    DKG999
  • Ron Temple
    edited August 2007
    appadv wrote: »
    25-31+ or another PC/B+ would be the minimum I'd go in that room...you're right...too big for a single SB.
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Serendipity
    edited August 2007
    Thanks. Although my current sub is calibrated -3db lower than the mains, it's a monster sub and fills the room with ease. I'd think a sub such as the 25-31PC+ will at least match my DIY sub for output.
  • rtart
    rtart Posts: 852
    edited August 2007
    I've got two 25-31PC Plus's in a fairly large room, and play a lot of DVD audio discs and SACDs. I use a Velodyne SMS-1 for bass management, and couldn't be happier. The SMS-1 allows several different bass response curves for different listening needs. The one for movies has a little more emphasis on explosions and LFE, while the one for music is, well, more musical.
    A sub should ideally reproduce the signal supplied to it accurately, and should not "color" its sound. The SVS's do this as well as any subs around. The overall goal, of course, is to interface the subs with the room without adding boominess or other resonances. The only way I could fully take advantage of the subs in my HT was by using some sort of bass management system. I started with a Behringer parametric EQ, manually calibrated with a SPL meter and graphing software, and eventually invested in the SMS-1, which has an auto-cailbration capability. After installing and calibrating the SVSs, I initially noticed less bass at times. I eventually realized that my old uncalibrated subs sometimes sounded louder when they interacted with my room at some frequencies (boominess)and the SMS-1 fixed that. I also found that several spots in movie soundtracks had enormous LFE responses, where I had not noticed them before. The SVSs certainly have the guts to reproduce the bass when needed.
    Just my $0.02 worth.
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • Serendipity
    edited August 2007
    rtart wrote: »
    How large is the room?
    I also like a well-calibrated sound from my subs.
  • rtart
    rtart Posts: 852
    edited August 2007
    My HT is 16' x 27', with 9' ceilings. Around 3,600 cubic feet. Two SVS subs fills it well. However, I have RT2000p's as mains, two CS400is for centers (trying to find a CS1000p to replace them), two FX1000's for side surrounds and two RT1000is for rear surrounds. The subs in the RT2000p's provide enough bass for most people, but I really believe high bass sound pressure levels add a LOT to the movie experience. i also have bass shakers in each chair, and love to see people jump when an explosion goes off in a movie.
    HD-A35 HD DVD
  • Serendipity
    edited August 2007
    rtart wrote: »
    Very similar to my room. I'm also considering two SVS subs (preferrably the 25-31PC Plus) to fill the room with balanced sound.
  • rtart
    rtart Posts: 852
    edited September 2007
    Can't beat SVS for price/performance. I had friends over last weekend and played the Spiderman 2 scene where the bad guy turns on the evil machine. When the lasers turn on, and the machine starts up, the sound is heart stopping.
    I chose dual PC plus's instead of the PC Ultra based on price and value. The PC Ultra is basically the PC Plus with a single band EQ and I think a larger amp. Bass SPL is about moving air, and a single sub has to have a LOT of travel to move as much air as two subs. A SMS-1, or one of the new receivers with bass EQ (like Audyssey Multi XT), or a Behringer BFD EQ will allow you to tailor the sub to your room. You can but two PC Plus's and a BFD for a couple hundred more than a PC Ultra. (However, if I could find a couple of Pc Ultras used at a good price......)
    Take a look at SVS B-Stock section to save a few bucks.
    BTW, the 25-31 is the right choice for HT.
    Have fun!!
    HD-A35 HD DVD
  • Serendipity
    rtart wrote: »
    How's it for music though?
    I'm looking for a sub that sounds good with both movies and music.
  • MikeC78
    From the reviews over at AVS, the new SVS Ultra PB13 is the king. Outgunning the new $3500 JL Audio Fathom 113.
    http://www.avsforum.com/avs-vb/showthread.php?p=9164136#post9164136
    http://www.avsforum.com/avs-vb/showthread.php?t=889659
  • Serendipity
    MikeC78 wrote: »
    Impressive sub. Looks like it's perfect for my HT at home.
    A little overkill for my dorm room though...
    Too bad I'm in college right now.
  • MikeC78
    Perfect sub for a dorm room!:D
  • beardog03
    beardog03 Posts: 5,550
    I find myself lusting after the new SVS sealed 12, and the new Ultra..
    The SB-12 plus keeps calling my name !
    I think I will sell my PB10 (Nice little sub !), and maybe my PC-Ultra and get them both (ultra 13& SB12)
    I am completely sold on SVS...outstanding products, and stellar CS
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • kuntasensei
    kuntasensei Posts: 3,263
    In my opinion, the "musicality" of SVS subs is entirely dependant on proper setup. Because they aim for flat anechoic response by design, you really need to make sure that you have all your speakers in phase with the sub (double-checking distance/delay settings helps) and nail optimal crossover points for your speakers (1/4 to 1/2 octave above the speaker's -3dB point is a safe bet).
    I've been running my 20-39CS+ with an ART-351 EQ since I got it so I could smooth out room response, and I've always been fairly happy with how it sounded with music. Then recently, I upgraded my receiver to the Onkyo 705which has Audyssey MultEQ XT... and that sucker did such a great job of equalizing my speakers and sub that I don't need the ART-351 anymore. Musically, it's now like I'm in the room with the bassist.
    So basically, it's like having a really nice car... You have to tune it to get the most out of it. Regardless, I'd shoot an e-mail to Ed at SVS and he can give you a good idea of which sub works best for a given room size, setup and sound.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • Serendipity
    Which amp are you using with the CS+? I like the powered PC+ and PB+ models but would like to know about going with a "separates" approach (amp+sub).
  • rtart
    rtart Posts: 852
    appadv wrote: »
    Not to hijack, but I've had SVS passive and active subs. I now use the actives, simply because it's usually cheaper watt-for-watt to buy active than to buy the subs and amps separately. I used a Carver 251WPC amp, which worked fine, but I already owned it. Would have been a lot more money to buy the amp and passive subs than to buy the PC Plus. In addition, the active amps usually have some crossover and phase control, and the separates do not (unless your receiver does it.)
    HD-A35 HD DVD
  • kuntasensei
    appadv wrote: »
    I'm running the Samson 1,000w rackmount amp that SVS offered when the Plus line first came out. At the time I bought, the powered versions had not yet hit the market. Currently, I'm running 500w to the SVS and 500w to a Buttkicker LFE under my couch.
    That said, I would have jumped on a powered version had it been offered at the time. But in my case, it worked out eventually because I had the extra channel on the amp for the Buttkicker later down the road. As far as whether there is an advantage to going the CS route, I don't know that I'd say so. The amps that SVS are using work great, there are plenty of adjustments available to tweakers, and they've set the limiting, etc. based on the sub's design.
    Equipment list:
    Emotiva XPA-3 amp
  • beardog03
    Skipping through the thread, I gotta say...I hear the SB12 is a good "musical" sub..
    can`t wait to get my paws on one to see for myself..
    I really want a smaller musical sub for my 2 ch rig...
    The octagonal shaped one (forgot name) that I saw when I picked up my pb10 was supposed to be a great musical sub...I also think it was an 8 ", not sure though
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • McLoki
    McLoki Posts: 5,231
    appadv wrote: »
    I am using one channel of my Cinepro to run my 25-31cs+ sub. It sounds great. I am going to be getting a 25-31PC+ in the near future (as a second sub) and will let you all know if there is any sound difference between the two. (The Cinepro is about the same power as the amp in the PC+ - I would guess better quality as well, but I don't know if that will translate into better sound or not.)
    I will let you know what I find out.
    Michael
