Installation of pre-construction brackets
Zamps
Zamps Posts: 48
Anyone have some tips for installing pre-construction brackets for in-ceiling speakers? I'm going to install some for 2 pairs of TC80is. I'm a little confused how the drywall is installed with the "lip" that hangs down around the speaker opening.
Any pointers would be helpful. Thanks.
Display: Mitsubishi 52" WD-52527
AVR: Denon AVR-1909
DBS: DTV HR20-700
DVD: Samsung DVD-P421
Video Game: Sony PS3, Wii
CD Changer: Sony CDP-CX335
Fronts: Polk RT800
Center: Polk CS400
Surrounds: Polk TC80i (4)
Sub: Polk PSW450
Misc.: Monitor 5JR
Post edited by Zamps on
  • Zamps
    Zamps Posts: 48
    edited August 2007
    Well I went to install my pre-construction brackets this afternoon. Turns out there is a HVAC duct running in the joist where I was going to place the surround back speakers. So it looks like I'd have to move them back. Anyone think they would be positioned too far behind the seating area?
    AVR: Denon AVR-1909
    DBS: DTV HR20-700
    Fronts: Polk RT800
    Center: Polk CS400
    Sub: Polk PSW450
    Misc.: Monitor 5JR
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2007
    On your drawing it looks like you have the measurements in feet? If it is to scale this a huge room? If you meant inches then your positions would seem to be ok, some folks have the back surrounds right next to each other. Having them up high over the listening postition's heads level as you do is a plus. You are going to be able to balance the sound coming from them with the rest of the speakers as far as volume goes.
    By construction bracket do you mean a performance enclosure? Polk does make them along with construction brackets to help center the speaker? If you are not using an actual performance enclosure I would recommend you do. You would install the perfromace enclosure level to the framing in the soffet/ceiling, then the drywall goes up and the speaker slides through the hole in the drywall.
    Hope this helps a bit.
    RT1
  • Zamps
    Zamps Posts: 48
    edited August 2007
    I wasn't planning on the performance enclosure but I could probably come up with something. The speakers are placed in the ceiling between the I-joists, which are spaced at 19" on center and are approx. 12" deep. The LC specs state a recommended volume of 1.4 cf, and for a 2"x12" stud wall a spacing of 15". I could probably put some blocking up at that spacing for each speaker. Is it really going to affect the sound that much?
    AVR: Denon AVR-1909
    DBS: DTV HR20-700
    Fronts: Polk RT800
    Center: Polk CS400
    Sub: Polk PSW450
    Misc.: Monitor 5JR
  • doggie750
    doggie750 Posts: 1,160
    edited August 2007
    I'll do the surrounds, but not the rears unless you have the energy to do blocking. As far as sound quality for your rears it wont make any diff coz you'll only hear in seconds. IME.
    Reeltrouble1 made a suggestion, place your rear closer.
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
  • Zamps
    Zamps Posts: 48
    edited August 2007
    Thanks for the suggestions.
    I can't move them closer because there is duct work running thru the joist. It looks a little off on paper, but when you actually look at it in the house it looks okay.
    I can't wait to install and watch a movie! Now what movie to pick?! :)
    AVR: Denon AVR-1909
    DBS: DTV HR20-700
    Fronts: Polk RT800
    Center: Polk CS400
    Sub: Polk PSW450
    Misc.: Monitor 5JR
