would you consider the rti12 a 2 channel speaker?
JimBRICK
JimBRICK Posts: 1,543
edited August 2007 in 2 Channel Audio
Just wanted to get you opinion on this guys. With the crazy prices out there right now they are worth a look.
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • MikeC78
    MikeC78 Posts: 2,315
    edited August 2007
    IMO, NO. Great HT speaker.
  • Mazeroth
    Mazeroth Posts: 1,585
    edited August 2007
    A great 2-channel speaker makes a great HT speaker. Not quite sure how a great HT speaker couldn't be a great 2-channel speaker?
  • MikeC78
    edited August 2007
    Mazeroth wrote: »
    There are many reasons, and remember these are opinions, just like the ones you stated.
    I use to own the RTi series, loved them for HT simply for the more straight forward / bright sound. Hated them for music as they were way to harsh for my tastes.
    Different strokes for different folks. I don't even know why people ask these questions without hearing them for themselves. The best possible answer you could have, not someone elses opinion.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited August 2007
    I would say if you have tubes in the path,they will do...I hooked our 12's up to the 2-channel set-up not so long ago,and they sounded very good,better than I expected.
    I have them powered by a pair of Adcoms in our HT rig,and the tweeters are a little too bright for my tastes.
    After coupling them with a little better gear,with some tubes in mix,the tweeters smoothed out very well...made them a lot easier to listen to.
  • dorokusai
    dorokusai Posts: 25,577
    edited August 2007
    That series sounds great with tube amplification.
  • Yashu
    Yashu Posts: 772
    edited August 2007
    I had a set of RTi4s for a period and did not like them for music at all. The 12s use the same tweeter, and that is what I had all my qualms with, the harsh and bright high end.
    I would imagine that a tubed system would tame them a little bit, but to a degree that makes them great for music, you might need a tube poweramp, not just a tubed pre, or a DAC with a tubed output buffer, for example. I mean, my ears are really sensitive to HF, so it would be personal preference too... With the right amps they are going to sound pretty airy and spacious, all good things, if you can stand a little fatigue with some recordings.
    Polk pretty much built the RTi series for serious home theatre, and LSi for serious music.
    heiney9 Posts: 25,203
    edited August 2007
    This is a very difficult question for others to answer for YOU. There are so many levels of experience and likes and dislikes. For me personally the RTi line wouldn't make a good 2 ch music speaker. I hvae no idea if it would for you. You can draw some general conclusions based on what others tell you but until you get your ears on them in your setting you won't know.
    I've bought gear before based on professional magazine reviews and was disappointed. I've heard gear that generally gets great reviews here and other places and just didn't feel it was all that special like some said it was. And was very happy that I didn;t buy it.
    treitz3 Posts: 19,195
    edited August 2007
    Would you consider the rti12 a 2 channel speaker?
    Hell no.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2007
    I think the Rti series sound great 2 channel or HT with Parasound amps... But I been told I like it bright, but I like ML also are these consider bright?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
