How to check for common ground
I need a quick answer for the exact procedure to check and see if an amp is common ground.
My understanding is I take my Ohm meter and put the leads across the negative terminals on the back of the amp and if there is a reading then it's NOT common ground. If there is no reading then it IS common ground?
Have I got this right and of course the amp should be powered off. I have an opportunity to buy a Monarchy SM70-Pro and need to find this info out.
Post edited by heiney9 on
H9 - try it on the Yamaha integraged, because I know it is common ground. Doug.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
PM sent.
there should be continuity between grounds. Anatech told me this trick, and also recommended tyeing the grounds together with some heavy gage wire as insurance,Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
In case it's not obvious: Do NOT tie the grounds until you've established that it's a common ground amp.
One other trick for figuring it out without having the amp in front of you: If it's got a bridge switch, it's common ground.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Would never tie the neg. terms together without checking first, thanks .One other trick for figuring it out without having the amp in front of you: If it's got a bridge switch, it's common ground.
Even if it's a single ended amp? Meaning it's not a typical push/pull type amp. The Monarchy SM70 can be run in stereo or single ended mono.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Oh. That's weird. Bridged to Single ended mono? Ok, you've got me stumped- I get the feeling that it's not really bridging, but just freeing up the power supply to really push the one channel.
Normally, the bridge switch take a pair of SE channels and bridges them into a single push/pull configuration.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
I have to do some more research because I'm not sure how the Monarchy does it. It's my undestanding that when they are run in stereo (not their true design potential) their output is Class A and to my knowledge Pure Class A is single ended. These are 30 wpc in stereo mode and 80 wpc in mono mode.
The true design idea with these amps is to run a pair of them balanced mono and again they are single ended in that config.
I can get schematics if someone can determine if they are single ended in both setero and mono. I don't know of a true Class A design that isn't single ended, by the nature of the outputs being fully on all the time there is no push/pull thus being called single ended.
P.S. I do have an e-mail in to C.C. Poon at Monarchy who designs these products so I' sure he will know if I can ask the right questions and make them clear enough for him to understand."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul!
