Totem Sub on Audiogon with weird claim...
SolidSqual
SolidSqual Posts: 5,218
edited August 2007 in Speakers
http://cls.audiogon.com/cgi-bin/cls.pl?homesubw&1191279139
Would you pay $1195 for a half broken sub that retails for $1600? This guy thinks I should! Read below.
"Here's the deal with this sub. As you know there is a left right input for the sub and somtimes people use a jumper to go from one to the other, well the tip from the rca broke off in one side. I have talked Totem and they said you only need one of the inputs and it doesn't matter which. I use the sub and it's perfectly fine but you should be aware of this."
Essentially, he's saying Totem just added the RCA in Stereo for s**ts and giggles. My instinct tells me this would affect synergy and balance.
Post edited by SolidSqual on
    treitz3 Posts: 20,017
    edited August 2007
    Just a thought. You could use a small reamer to remove the pin easily. Use the fact that it is "busted" to influence a price drop. He did say OBO.;)
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited August 2007
    That....
    and zero feedback.
    But it's my understanding that it should work fine. You should only lose about 3db by running a cable to a single input. But maybe I'm wrong.
  • SolidSqual
    edited August 2007
    really . . . so it the bass signal the same out of each channel? That can't be . . . what about a big bass playing on the left of the soundstage with PAtricia BArber belting out a tune on the right? Wouldn't I miss the bass signal if the sub was hooked to right output?
  • zombie boy 2000
    edited August 2007
    Ah.... I see what you're saying. I was thinking of a single sub output. Such as those found on AVR's. You're rolling with a second set of outputs on your preamp.
    Nevermind then. Moving along.
  • tcrossma
    tcrossma Posts: 1,301
    edited August 2007
    I believe the bass signal is a mono signal and the two RCA's on the sub are merged internally. Whatever bass management you are using should join the bass coming from the L/R into one mono signal. If not, you could use a Y adapter and plug it into the good connector on the sub. Either way, it should be fine. I think. Maybe.
    tim
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    Its still USED!!!!
    Priced way too high.
    If I had the $1200 I would find or save the extra $400 and get it BRAND NEW.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • SolidSqual
    edited August 2007
    I agree. Overpiced. NO Rep. USED. Plus, who knows how it's been knocked around to lose an RCA plug. I own Totem. The stuff is built pretty solid.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited August 2007
    That's a handsome subwoofer.
  • SolidSqual
    edited August 2007
    She is a beaut. But, I can't bring myself to even begin bidding on a broken product.
  • jakelm
    jakelm Posts: 4,081
    edited August 2007
    Now if it were $800 or $900, then yes I would deffinatly consider it.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • SolidSqual
    edited August 2007
    I just tested my theory on my own sub. Musical info. is lost. Unless you are listening to rap or a movie. The bass lines of certain cds are not equal across the soundstage. Thus, you need both plugs for the right experience. Granted I'm using my preamp outs and not an LFE out.
  • tcrossma
    edited August 2007
    I don't know your setup or that particular sub. But if the sub doesn't combine the signals internally you could always just use a Y at the sub. Either way, it's only a single speaker so it shouldn't be necessary to feed it a stereo signal.
  • Gaara
    Gaara Posts: 2,415
    edited August 2007
    Seems like a miscommunication between solid and tcross.
    Solid, I know what you are saying, and there are devices that can combine the stereo out to mono for cheap if you ever were in such a situation.
    Tcross, it is a normal setup with a normal sub it seems. What he is saying is he is using the L+R pre outs of his pre, which is why he would need 2 inputs. With one you have to choose L or R, and you miss the bass from the other side. Most people just use the sub out and have the bass crossed over, but if the sub is used just to enhance the fronts then it isn't so easy.
  • michael_w
    michael_w Posts: 2,813
    edited August 2007
    It just has the tip stuck inside it. That shouldn't be too hard to pull out and as long as the actual jack isn't damaged it should be good to go.
  • SolidSqual
    edited August 2007
    How bout we have everyone on this forum contribute a dollar to buy this thing. Then I'll ship it off to that guy who blends all sorts of things on YouTube with his HiSpeed/Powered Blenders.
    http://www.youtube.com/watch?v=B8H29jU8Wrs&mode=related&search=
  • tcrossma
    edited August 2007
    Gaara wrote: »
    Ah, ok. But wouldn't you still be able to use a Y at the sub? L/R pre-outs to a Y to the single RCA at the sub? That wouldn't work?
    Thanks,
    tim
