Affordable Audio August Issue
markmarc
markmarc Posts: 2,309
edited August 2007 in 2 Channel Audio
Fellow Audio Enthusiasts:
The August issue of Affordable$$Audio is now available for free download in either the dual or single column format at:
www.affordableaudio.org
Thanks for reading!
Former Staff Member TONEAudio
2 Ch. System
Post edited by markmarc on
  • engtaz
    engtaz Posts: 7,669
    edited August 2007
    engtaz
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited August 2007
    I am still getting double columns when I click on the Single Column choice.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    edited August 2007
    Just finished the Totem sub review and look forward to the rest (esp. the Monarchy DAC/linestage update). Thanks as always for a stellar online pub!
  • markmarc
    edited August 2007
    Ok, the single column link is fixed, you may need to refresh the browser. A bit late last night when I finished, no wonder I made that stupid error!
    2 Ch. System
    heiney9 Posts: 25,435
    edited August 2007
    My bro just got one of these as well as the SM70 pro's brand spanking new and I can't wait to demo the NM24 in my system. So far he is thrilled with both the Sm70 mono's and the NM24
  • Fireman32
    Fireman32 Posts: 4,845
    edited August 2007
    I got an error 404 trying to open the single column version. Will try again in a bit
  • zombie boy 2000
    edited August 2007
    heiney9 wrote: »
    I can't wait to hear your review... I'm rolling with a tube CDP right now (pun not intended), so I might be missing out on one of the CDP's perks by throwing a tube DAC into the mix. Or maybe I'd be doubling my pleasure?
    Hopefully you'll get a chance to demo the SM70 Pro's in your system as well.
    edited August 2007
    First off Nice Job again Mark!!! I continue to enjoy the issue every single month.
    Zombie, that's the plan. Since I runs SDA's the mono blocks are probably out as I'd have too much DIY involved to make an AI-1 cable. So far my bro is ecstatic about the NM24 and SM70 pro configuration. This is no small feat as he had a Monarchy M33C (dac) before and an Adcom GFA-585. He is continuing to use an Adcom GFP-750 as a pre amp and then using the tube output sect of the NM24 as a dac only. Oddly teh NM24 doesn;t have balanced connections and most people agree the SM70's sound best when run in balanced single ended mono. The Adcom pre amp does have balanced connections and works great.
    I hope to demo the NM24 in my sytem and if it makes the diff I think, I will be getting one myself. I'm also going to try a single SM70 run in stereo to see how that works out. I have to talk to C.C. Poon and make sure when run in stereo they are common ground.
    If the SM70 won't work with my SDA's I'm looking at Pass Labs amp like the Aleph 3 or 30 or the New Aleph J (impossible to find) or maybe even spring for a used X or XA 150. Big bucks though. I've also been looking at used Classe amps (CA100, 101, 200, 201). I'm not going to rush into anything but if the NM24 is a huge improvement it's a no brainer and then I'll go from there.
  • bugner
    bugner Posts: 56
    edited August 2007
    Mark, both of your e-mail accounts are "temporarily disabled." I need to make contact about a potential review, and the manufacturer will be contacting you as well. If you see this, send me a PM with a good address, if you would.
    steve eddy
