Good tweak
PolkThug
Cup hands behind ears to increase resolution.
Post edited by PolkThug on
SWEET!!
Thanks Thug, this is the low budget tweak ive been looking for!!Television: Mitsubishi WD-57732
Front R/L: Polkaudio RTiA7
Center: Polkaudio CSiA4
Rear R/L: Polkaudio FXiA4
Subwoofer: Polkaudio DSW600
A/V Reciever: Denon 2808
DVD/SACD: Sony Playstation 3 -
I heard this one works a little better."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
This actually works, BTW.
Now all I gotta do is create a device that will temporarily place your ears in this position and I'll be rich. Hmmm. An acoustically dampened duct tape, maybe?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Early, your too late!! Joe already has you beat to the drawing board. I've seen his device & he claims it works like a charm. Not the prettiest device...but as long as it works. Hopefully he'll be chiming in here soon."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Just pierce ears and run wire around forehead and pull forward. Oh I forgot wire might start to sing .
Be careful with taking credit for this idea, you'll have the lawyers from Machina Dynamica after you in no time.Wristwatch--->Crisco
How could we forget this gem!
http://www.polkaudio.com/forums/showthread.php?t=29641
Sorry Carl! Just having a little funCarl -
Thuggy it really does work! I have fashion an ear cup from "yourmusic.com" statments which are a rather heavy stock with a thick rubber band and I fit it on my impaired ear.
It reall does increase more than resolution for me! -
That would make the sound a little tinie and brassy don't you think!:D
