Sub Boxes
DrJoe
I have 10 inch subs. I was thinking about putting one in a sealed box and another in a bandpass box. What do you guys think of this idea?
Post edited by DrJoe on
Bad, bad, bad idea.
Mixing two totally different sounds together usually sounds like crap. Go with a sealed. If you want a ton of output, go ported. Stay away from bandpass. Way to hard to get those right and even if by some miracle you do, it wont be any better than a well built ported box.polkaudio sound quality competitor since 2005
That's what I thought.
I was reading on Crutchfield that ported boxes work the best with Hip-Hop and other music that doesn't require as accurate of bass as say, the fast bass lines in Old School Funk songs. I want to get the most bass for the money but I don't want it to sound like crap either. I was thinking of getting a dual 10 inch ported box.
I have 2 10 Inch Power Acoustik subs rated 600 Watts RMS and 1600 peak at 4 ohms. I was thinking of powering them with a Sony Xplod 1300 Watt amp that puts out 900 Watts RMS at 2 ohms. I'm going to wire the subs in parallel so I can drop their ohm load. I was just looking for feedback.
After I get all that installed, I'll have an old 800 Watt 2 channel Kenwood amp just sitting around. The Amp is rated at 150 RMS into 4 ohms on each channel. This amount of power is okay for a small sub, but it will blow right though most coaxial speakers. My idea, this might be crazy, is to wire 2 speakers to each channel in series, thus bring the ohm load to 8. I was thinking I'd get about 50 watts RMS into 4 speakers. -
Usually the best way is to buy a pre-loaded ported box. Generally these are designed specifically for the subs theyre using so youll get a good compromise between maximum boom and good SQ.
The DB212-2 for instance is a perfect example.polkaudio sound quality competitor since 2005
