Cinenova owners I have a power question
sabotg
sabotg Posts: 126
edited August 2007 in Electronics
I'm wondering if it might be a good idea to run a seperate 20 amp circuit to power my 7 channel cinenova. The socket im plugging into is a 20 amp socket and I'm not sure if it can take the AVR, cinenova, xbox360 and TV without popping the breaker. I guess I could give it a try and see what happens but was wondering about your experiences with the amp.
Post edited by sabotg on
  • venomclan
    venomclan Posts: 2,467
    edited July 2007
    sabotg wrote: »
    I do not own this particular amp but I have used multiple powerful amps on one shared 15 amp circuit. Most of the time, your gear will draw very little power from the wall, it is only at loud passages that a draw can be difficult. A sperate 20 amp line will provide the best option though.
    With all my gear running and the TV (36" CRT), my power conditioner showed that no more than 4 amps were ever being used at once. At start up, my tv can pull 12 amps for a few seconds, then drops to 1-1.3 during use.
    V
  • m00npie
    m00npie Posts: 697
    edited July 2007
    sabotg wrote: »
    I doubt you will pop the breaker if those are the only items on that breaker. Question is, what else do you have on it? Lights, sockets or dimmer switches may not advisable since it could introduce noise into your setup. If you have the means, run a dedicated line to it.
    I ran two dedicated 20 amp circuits; one line using 10/3 and the other line using 12/3. I have my Cinenova and my Denon 4306 hooked up on one line and 6 other items using the other line. My setup is most likely complete overkill but who cares. It was easy.
    Good Luck!
  • sabotg
    sabotg Posts: 126
    edited July 2007
    I'll check on what else is on the circuit. I suppose I could hook it up and give it a test run and add the dedicated circuit if I have any noise or breaker issues.:p
  • Gaara
    Gaara Posts: 2,415
    edited August 2007
    You should be fine.
    For reference I have a Cinenova Grande 5.
    I have had it hooked up on it's own 15 amp circuit with no issues
    I have had it hooked up on it's own 20 amp circuit with no issues.
    I have had it hooked up with all my other gear (Pre-amp, CDP, DVDP, PS2, XBOX, GameCube, 34in tube TV, EQ...etc) with no issues.
    I checked my power draw a while back and the most I ever drew from the line playing a movie at reference levels was about 6A max with averages around 4.5A.
    VR3 Posts: 29,697
    edited August 2007
    I've ran...
    5 amplifiers, a receiver, cdp, dvdp, tv, powered sub, xbox, vcr on one power strip.
    No problems.
    I run all my current gear, minus the subwoofer amp all on one outlet as well. :)
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited August 2007
    I have my Cinenova on a 20 amp dedicated circuit.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
