Alpine 9887 vs Eclipse 7100????????:eek:
Kenji_lim
I facing a problem of choosing these two HU...any suggestion?????
Post edited by Kenji_lim on
I had thought about giving the CDA-9887 a try. Looks like Alpine is on the right track again, at least with this unit....or so I thought. I have looked over the owner's manual that I downloaded from the European Alpine website. I also read this review....#30...Link
.... At this time I would definately go with the CD7100.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Go with the eclipse. I just got over the horrible experience of using a cda-9885. The thing had crappy sound and it wasn't able to drive my amplifiers to their full potential. When I replaced it with a jvc kd-avx33 the whole system just pounded so much harder and so much clearer. I had all these weird problems with the alpine with the bass cutting out as the volume increased which is completely gone with the new HU. When I called alpine, they refused to believe their head unit was doing it but it is obvious that's what it was. Stay away from that crap.
WHAT??? Alpine's always been the top-of-the line head units. What happened to them?
I believe Alpine stopped being on top a few years back. Maybe not in sales, but with the product that they were putting out. I believe this HU (9887) is a very nice unit, just not exactly what I was looking for. SQ wise, it looks like you can build your system around it. As time goes on you expect new products to be better. Seems like the user interface is not as simple as before, and the display does not do what the CDA-9835 or CDA-7998 did. I think it has alot to do with how much smaller the display is.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
Whatever, Alpine sucks. I told you already that it just doesn't make your system play as loud and hard as some other manufacturers.
I would look into how your system is tuned....you may have had a bad unit as well. What unit did you have before the Alpine? Did you reset your gains? What are your settings on your amps (did you have your bass boost)? To say that the whole company sucks due to the possibility of a bad HU does not make any sense.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
I have a 9885 and it works perfect, try a better install, or maybe u got a bad unit.2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8 -
What are you looking for in a hu? And what do you like about these two.HU: 880PRS
Front: SR6500
Amp: Alpine MRV-F545
Sub: SR124-DVC
Amp: Alpine MRD-M1005 -
thanz for helping..:)
i am using c400.4 for mmc6500 component in front door panel and mmc650 at rear..with active subwoofer at bottom passanger seat.. in toyoya wish.i test both of these HU..as the result...the winner is Eclipse cd7100...it sound amazing..hard to explain with word..it sound so flexsible and so wide..it produce clean highs sound that other HU can't do..i think i am choosing the right HU....thanz all of u guy helping..i think u guy should try it..:)
and now i am broke coz Eclipse cd 7100 much more expensive..:D
What did you pay for it? I need a new HU soon. And, does it have a aux in?
I believe that it does, & no adapters are needed. You can set the gains on it too. This is the way it is on my CD7000. You also have the option of adding another one with an adpater.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
Jack from Indo wrote: »What did you pay for it? I need a new HU soon. And, does it have a aux in?
yes..include aux option..but tuned need more time coz it option co much including x-over/time alignment and 11-band PEQ..u'll get what u want..:) -
Why not pick up the Pioneer PRS 880 at almost half the price of the cd7100?
Link to a review...
http://www.nissanclub.com/forums/car-audio-multimedia-ice/248325-comparison-pioneer-premier-deh-p-880prs-vs-eclipse-cd7100.html
I had thought about giving the 880PRS a shot, but opted for a unit that is easier to use, and one that does not have a history of noise problems, and blown internal fuses.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
i own Pioneer8600 it not good as cd7100
I also owned the DEH-P8600....two different times....and I agree with you.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
dose anyone know how good the ipod controle on the 7100 compares to the alpine or pioneer.SR 4 Life
The ipod control is the best on the alpine. But the sound certainly isn't. It absolutely will not drive your amps as hard as the eclipse. I know this firsthand.
