Jumpers
I need some jumpers for my newly acquired LSi9's.
Do I need over sized spades or standard?
Trying to stay around $20 to $30.
Someone her linked to this site, but I can't find the thread.
http://www.zuaudio.com/julian_jumpers.asp#
This is what I'm using now, all I had on hand to throw together.
Post edited by brijenjas on
I just use some good 12-14 guage speaker wire,,just my .02JC approves....he told me so. (F-1 nut)
I used 12 gauge stranded high copper wire from Radio Shack.
george daniel wrote: »I just use some good 12-14 guage speaker wire,,just my .02
Do you use any termination, or just the bare speaker wire?
Has anybody tried these;
http://cgi.audiogon.com/cgi-bin/cl.pl?cablspkr&1190234165 -
Those look good.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
just tin (solder) the ends of the wireJC approves....he told me so. (F-1 nut)
george daniel wrote: »just tin (solder) the ends of the wire
My speaker cables are terminated with spades.
If I use the wire for jumpers will the binding post nuts clamp the speaker wire to the spades, or will I still need some kind of adapter? -
the stock jumper will be mailed to you, hang in there.
RussDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Russ
Thanks for the offer Russ, but save your postage.
I planned on upgrading jumpers anyway.
I'm going to try the ones at Audiogon I linked to, just waiting for an email back for color options. -
I ordered the jumpers from the link above on Friday 7/27 evening and they got here Monday 7/30.
I ordered the 10ga version and these are pretty stiff, should have gone with the 12ga version.
They appear to be very well made.
