If you had a chance to put in all new HT wire...
dpowell
dpowell Posts: 3,068
edited July 2007 in Speakers
I have the opportunity to wire an 18' X 19' room for HT with the drywall off. My main question is whether to use 12gauge or 14gauge wire for the speakers. See my sig for equipment being used. I currently use a 5.1 setup. Would I be short-sighted for not running a second set of rear cables and leaving them in the wall in the slight chance I'd upgrade to 7.1 down the road?
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
  • Bamadude
    Bamadude Posts: 245
    edited July 2007
    You're exactly where I was a couple months ago with the drywall off and trying to make a decision about wire. I ended up going with 12gauge from bluejeans and went ahead and pulled wires for 7.1 while I was there just in case. Might as well while since the wire isn't that expensive and much easier with no walls. I know I'd kick myself the first time I heard a killer 7.1 :).
    AVR: Pioneer VSX-84TXSi (RIP - lightening) / Amp: Sunfire Cinema Grand / Klipsh R-10B Sounbar, LC65fx / Sub: Elemental Designs LT/1300 / TV: Panasonic TH-50PH9UK /SIZE]
  • Skynut
    Skynut Posts: 2,967
    edited July 2007
    I would run 10ga just because.
    I would also wire it for easy speaker relocation and possible 7.1 upgrade.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
