C500.1 question??
greg2350
This is for anyone running the C500.1 do any of you use the remote gain control?
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX
AVR: Denon 3801
Sat: Directtv HD 10
Post edited by greg2350 on
I do not have the 500.1, but have used that function on several other amps. If you listen to a wide variety of music, as I do, you will encounter some music recorded with alot of bass and some on the other end of the spectrum. I have found that the subwoofer level control on a HU is often not wide enough to accomodate both ends of the spectrum (of the HU's Ive used, Pioneer is the one exception I have found). So I ended up using it when I needed a little more energy in the bass region.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
I have a c500.1 and I use my bass gain remote. Like blackmax said, its not really necessary if you have a good deck, but I still use mine from time to time.
I believe the Alpine CDA-7998, and CDA-9835 qualify as good HU's. As well as the Eclipse CD8455, and CD7000. I still found myself having to use it with these units
. That is one thing I do miss about the Pioneer units....the wide adjustment mode for the sub.
Of all those, Eclipse gives you the narowest margin, but the SQ is worth it
. Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
Thanks for the response guys like blackmax I listen to a variety of music so I think I will hook it up. The deck im using is a Kenwood excelon dpx-701 which is a low end unit. I got this HU mainly for the DD size and it has some cool features like USB, im sure the SQ is much better with the alpine and eclipse and not to mention the price I paid for it $200. The sub level control seems ok but I think I would like the control at my fingertips.TV: Philips 42" LCD 1080p
AVR: Denon 3801
Sat: Directtv HD 10
Center Speaker amp: Rotel 970 BX -
I'm the same way. I listen to pretty much every genre of music, and some songs sounds good with very little bass, other songs are the exact opposite.
The good thing about the remote is you can just grab it and twist on the fly as needed, and keep your eyes on the road. You don't need to go pushing through menus to get to the right adjustment, staring at the LCD screen.
That little gizmo might save yer life one day. -
Yes, it works well. Just don't run more than two 500.1's off of one remote.
Why not? I was thinking of doing that using a splitter. -
Thats the main reason I was going to hook it up jack it gets annoying flipping threw the menus just to adjust the sub level.TV: Philips 42" LCD 1080p
AVR: Denon 3801
Sat: Directtv HD 10
Well I hooked it up and I must say why didnt I do this 3 weeks ago I love having the control right by my seat instead of having to flip threw the menus.TV: Philips 42" LCD 1080p
AVR: Denon 3801
Sat: Directtv HD 10
![[Deleted User]](https://forum.polkaudio.com/applications/dashboard/design/images/banned.png)
