PSW650 Question
tpeter
I just bought LSi Setup from polk and the PSW650 sub. It all sounds great but i want to make sure i have the Sub hooked up right. I have a ONKYO TX-DS797 and have the Cable going into the LFE on the Woofer. IS this the correct setup?
Polk LSi 15
Polk LSi/C
Polk LSi/FX
SVS Ultra
SVS PB3000
Monolith 15 THX
Denon 3700h "switching to Onkyo rz50"
Monolith 7 AMP.
Polk LSi/C
Polk LSi/FX
SVS Ultra
SVS PB3000
Monolith 15 THX
Monolith 7 AMP.
Post edited by tpeter on
In short, yes - that should work just fine for home theater use. It may not be the best option for music though, but that depends on your personal preference.
Welcome to the wonderful world of Polk Audio! -
Yes - I have the Onkyo787 and have all subs hooked up lfe. If your sub has both L and R inputs I would recommend using a y adapter on the sub. You reciever also has a Bass Management system that will alow you to "tweak" you subs output.
