HOLY Sony Tower of POWER! AMP ****
XJRGUY
XJRGUY Posts: 258
edited November 2007 in Electronics
Three TA-N9000ES' in BTL mode
One STR-DA777ES acting as pre-amp controllin' it all
  • 66chevyIISS
    66chevyIISS Posts: 857
    edited July 2007
    no SONY play station? lol should hide the Xbox
    My Home Theater (WIP):
    Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
    Receiver: Denon AVR-1905
    Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
    Dual Subs: PSW202, and behind the couch Denon 8"
    My showcase link:
    Media Room pics
  • swegyptian
    swegyptian Posts: 316
    edited July 2007
    Looks great! Now toss them in a rack where they will be all lined up and pretty!
  • XJRGUY
    XJRGUY Posts: 258
    edited July 2007
    Hahaha, yeah that is pretty funny. Didn't think about that but it looks like David vs. Goliath!
    XJRGUY
  • XJRGUY
    XJRGUY Posts: 258
    edited July 2007
    swegyptian wrote: »
    Hi,
    That most likely won't happen. The wife and I picked these sturdy wooden A/V furniture out and it fits the decor. There is a second one to the left that you can't see in this picture. It's the same unit as this, but standing horizontally with our SXRD TV, RTI12 center and other components.
    Good suggestion though!
    XJRGUY
  • XJRGUY
    XJRGUY Posts: 258
    edited July 2007
    The funny thing is the warmest component out of all of them is the DA777ES.
    I'm not even using the internal amplification and it still gets warmer then the three outboard amps.
    I even have the rear 4/8 ohm switch set to 4 ohms, which lowers the power supply rail voltage to no avail.
    Not a big deal as that unit has always been hot blooded, but pretty funny considering the TA-N's don't break a sweat and the DA777ES amps are based on this technology.
    XJRGUY
  • G-force
    G-force Posts: 82
    edited July 2007
    99% of xbox360's would brick just sitting next to those suckers.
  • XJRGUY
    XJRGUY Posts: 258
    edited July 2007
    hahah,
    You guys would die if I told you what I paid for the three of those.
    They are in brand new condition, had the recalls done, came with original box and papers.
    I love Internet deals!
    TA-N9000 #1 on top is set in BTL two channel bridge mode running the bottom half of my RTI12 fronts
    TA-N9000 #2 Bottom stack is BTL+1 running top half of RTI12 fronts and top half of RTI12 center
    TA-N9000 #3 Bottom stack is BTL+1 running both FXI5's (rear) and the bottom half of RTI12 center
    All of my RTI12's are bi-amped
  • BIZILL
    BIZILL Posts: 5,432
    edited July 2007
    G-force wrote: »
    if anyone retorts by saying that "99% of xbox360's would brick WITHOUT sitting next to those suckers", i'm gonna come UNGLUED!:rolleyes:
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • G-force
    G-force Posts: 82
    edited July 2007
    That thought did cross my mind....:p
  • cabolton13
    cabolton13 Posts: 72
    edited October 2007
    XJRGUY wrote: »
    hahah,
    how much did you pick those bad boys up?
    MY SYSTEM
    RT3000P
    CS400 (2)
    FX1000
    Sony ST-SA50ES
    Sony TA-E9000ES
    Sony TA-N9000ES (2)
    Sony BDP-S570
    Sony LCD 46"
    Technics SL-QD2
    Monster HTPS7000
    Directv HDTIVO
    PS3
    Xbox360
    Wii
  • cabolton13
    edited October 2007
    how much did you pay for those bad boys???
    MY SYSTEM
    RT3000P
    CS400 (2)
    FX1000
    Sony ST-SA50ES
    Sony TA-E9000ES
    Sony TA-N9000ES (2)
    Sony BDP-S570
    Sony LCD 46"
    Technics SL-QD2
    Monster HTPS7000
    Directv HDTIVO
    PS3
    Xbox360
    Wii
  • danger boy
    danger boy Posts: 15,722
    edited October 2007
    yes i'd like to know too. how much did you get those for... i'm not familar with Sony amps.. are these current or recent models of amps or older ones.. either way.. they look very nice and beefy
    PolkFest 2012, who's going>?
  • shadowofnight
    shadowofnight Posts: 2,735
    edited October 2007
    I used to have Sony ES separates for YEARS ( Still have a ES 5 disc changer... C87ES ) and after seeing you got some awesome deals on these amps post recall modded I did a search to see if I could pick one up cheap :) I found a couple of disturbing write ups on the amp ( Hopefully POST recall addresses this ? )
    Some more information on these from you would be greatly appreciated. Here is some that I saw.....
    " The first two samples failed with power supply problems. One literally exploded (the biggest bang HCC has ever heard in it's lab) as the volume was pushed. The second gave gross distortion. Sadly, this third sample - typical of one you might buy in the shops - also suffered similar traits under certain conditions.
    Our final lab test is to run every amplifier into dead short and open circuit loads. We short-circuit the speaker leads to simulate the type of accident that could occur in any home. An amplifier worth its salt should recover gracefully thanks to onboard protection. Sadly not this Sony.
    " Sony eventually confirmed that the transistor in the protection circuit was damaged by excess current generated by the HCC lab. This was because the resistor, which determines the amount of current flowing into the circuit, was inadequately soldered and in effect was short circuited. As a result, when the short circuit was detected, the abnormal current by-passed the resistor, affecting the protection circuit transistor and damaging the output stage. "
    Oh...and price if you could....
    The first rule of Fight Club is you don't talk about Fight Club
  • shadowofnight
    edited October 2007
  • XJRGUY
    XJRGUY Posts: 258
    Hi,
    sorry for the late reply.
    All of these TA-N9000ES units I have are all post recall serviced.
    I got each one for under $500, so around a $1500 investment for some really tight, punchy amps that are pretty transparent. They sound NIGHT AND DAY better than the Soundcraftsmen's I was using previously.
    These TA-N's originally sold for $1800 a piece.
    These units went out of production I believe in early 2000-2001.
    I run three of them in BTL mode and I BIAMP my front sound stage which is all RTI12. Needless to say it is very impressive.
    The system is driven by the legendary Sony STR-DA777ES.
    Right now I am listening to The Bee Gees "Nights on Broadway" in "Analog Direct" mode and man it sounds so damn good.
    XJRGUY
    P.S. Shadow of Night those units were prepreduction units that were tested.
  • XJRGUY
    XJRGUY Posts: 258
    danger boy wrote: »
    Danger Boy,
    I posted the prices in my last post.
    These amps are VERY CLASSY looking and perform to boot. They are not current models but were TOP OF THE HEAP of Sony ES separate gear back in the late 90's early 2000's.
    No meters, no junk on the front, just some understated operation LED's and one circular twist knob for operation of the amp.
    They have a nice warm up mode too and BEEFY binding posts. I leave them on 24/7 with no issues at all.
    Each one is about 52 lbs if I remember correctly.
    They run pretty cool too which is nice.
  • tecmo04
    tecmo04 Posts: 421
    ive been looking at picking up one of the sony amps used at a local shop here. Hes quoting me $509. where did you get them on the internet???
  • cabolton13
    you can search on ebay
    MY SYSTEM
    RT3000P
    CS400 (2)
    FX1000
    Sony ST-SA50ES
    Sony TA-E9000ES
    Sony TA-N9000ES (2)
    Sony BDP-S570
    Sony LCD 46"
    Technics SL-QD2
    Monster HTPS7000
    Directv HDTIVO
    PS3
    Xbox360
    Wii
  • XJRGUY
    XJRGUY Posts: 258
    tecmo04 wrote: »
    Ebay and Audiogon
    They were MINT condition, no dust, no scratches, no broken anything.
    I was very lucky
    I'm debating moving from the STR-DA777ES to a "newer" STR-DA7ES but really not convinced the DA7ES is going to be any better.
    Tim
