Which Sub Should I Use...
KiiNG 0F SWAG
I Have Two Subs Im Looking At That I Like But I Dont Know Which To Pick... So Im Asking For Your Opinions...
Orion H2 12.2 vs Eclipse SW6200
Their Both 12"
As Soon As I Make A Decision On The Sub... Ill Post A Thread About The Amp I Should Use
Their Both 12"
Post edited by KiiNG 0F SWAG on
Orion all the way. and plus its like a 700 doller sub and the other is 150.
if it was me i would go with polks SR12DVC you can get it for around 300
http://www.cardomain.com/item/POLSR124DVC -
It all depends on how much you want to spend and what you're looking for. Orion audio makes great subs but you're going to pay.
Some of the best 12 inch woofers. (The focal is 13 inch)
Focal K2 Power 33 KX
JL Audio 12inch W7
Polk Audio SR 124
Alpine Type X SWX-1243D
I think the Alpine is the lowest quality of the bunch.
All of these subs are going to sound great but you're going to have to dynamat your entire trunk to make them shine. -
man that sub is sexy
JL Audio 12inch W7
Polk Audio SR 124
I would not say that Alpine is the lowest quality of the bunch, the Type-X is a very nice sub. I was running one last year, that thing can play very cleanly, and can play very low. I currently have a W6v2, which is actually supposed to be a better sounding subwoofer than the W7.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin
