What is db rating and is better when its lower or higher?
1lakerfan
1lakerfan Posts: 112
edited August 2007 in Speakers
Thank you
Post edited by 1lakerfan on
    treitz3 Posts: 20,012
    edited July 2007
    Decibel rating and it depends on the speaker's characteristic's and efficiency.
  • MADGSF
    MADGSF Posts: 603
    edited July 2007
    It's not better either way it just is what it is. It does let you know that the lower the efficiency the more your amp will have to work for a given volume level.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • 1lakerfan
    edited July 2007
    so the higher it is the more it works or vice versa
  • ben62670
    ben62670 Posts: 15,969
    edited July 2007
    The higher the DB the less the amp has to work to put out more.
    Ben
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2007
    I am not sure he means speaker sensitivity/effeciency.
    Are you referring to the rating you see that says -3db? If so the lower the Hz the better and the higher the Khz the better. This number defines where the speaker rolls off as far as frequencies.
    If you do mean speaker sensitivity you will see a rating something like 89db 1khz @ 1m, in this case the higher numbers means the speaker will play louder with a given amount of power than a speaker with a lower rating.
    The sensitivity rating has nothing to do with the quality of the sound the speaker will put out. Just how much power you will need to drive it.
    RT1
  • ashkal
    ashkal Posts: 1
    edited August 2007
    if db unit of signal to noise ratio . better db rating is good.
    It is applicable to all equippmant, amp, cd player, dvd player,
    tuner ete.,
