blown sr104 dvc
lda2345
yea so i just blew both of my sr10dvc's. dose anyone know how long it takes to do a warranty return through polk? Also i was thinking about bumping up to sr124 dvc's. should i and will i notice the diffrence between the two?
SR 4 Life
Post edited by lda2345 on
One sub blowing could be bad luck....two blowing would lead me to check either my install or settings. Polk really takes care of its customers, so the turn around should not be too long.
Customer Service:
polkcs@polkaudio.com
9am - 6pm, M-F, EST (USA)
800-377-7655 toll free phone
410-764-5470 faxAlpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
Wrong box setup? Wrong amp settings? Distortion = death.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Maybe you needed to turn your gain back down.it smelled like a vc and its stoped now. i turned my amps up and gave them a good work out. i think that the excess glue was just burning off the voice coils. i only had my 500.1's gain turned up about a third of the way so i turned it up about two thirds of the way and the smell stoped and now my winshield flexes
yea i had my setings jacked up. what do you think about going to 12"s and will i notice the diffrence?SR 4 Life
stay 10's so you don't need to rebuild the box and all. But if you are using a prefab box, stick with the tens but get a real box made for them and get an amp that has lower distortion and enough power to give you what you're looking for.Never kick a fresh **** on a hot day.
iv got 10s in a prefab ported box now but im thinking about building a sealed box and going with 12's. as for amp wise i have 2 momo 500.1'sSR 4 Life
I have that exact same setup. 2 sr124 dvc in a sealed enclosure. Each sub is powered by a c500.1 at 2ohms.
The sound quality is exxxxxxcellent! However, 2 10's should be just fine also.
